"Correct" LED connection to 3PDT
Started by phillip, October 06, 2004, 05:55:41 PM
moogatroid2000
[/quote]You just permanently shorted the fx input and output across the switch.
Yeah I saw that in my head as I went to sleep. Guess I need to rethink it all.  :D
If both in and out could be grounded would that make any difference in regards to popping?
live and learn.
analogmike
HI,
Very interesting idea about the jack ground connections. But you can prove that will not solve your popping problem by wiring your battery clip black wire directly to the circuit board temporarily. If it still pops, your problem is elsewhere. Try it and let us know if it helps.
DIY has unpleasant realities, such as that an operating soldering iron has two ends differing markedly in the degree of comfort with which they can be grasped. - J. Smith
mike  ~^v^~ aNaLoG.MaN ~^v^~   vintage guitar effects
http://www.analogman.com
