easyvibe question
Started by dubs, September 02, 2003, 01:37:03 AM
dubs
I'm about to build the easyvibe from R.G's layout :
http://www.geofex.com/PCB_layouts/Layouts/easyvibe.pdf
which way do I install the leds on the layout? ie. which side is +ve and negative side on the circuitboard? And I'm assuming like resistors, that LDRs are non polar hence it doesn't matter?
Dan N
Looking at the parts side, with control leads going off the top, the led negs are all to the left.
dubs
Thanks Dan what about LED 5 & 6? From parts side up from top to bottom (LED 5 to LED 6) is it: +ve -ve, +ve, -ve?
Dan N
Forgot about those two. R.G. has a square pad for the pos, and round for neg. So- negs down toward the bottom of the pcb.
Good luck with your build. Mine is still in octapus spagetti condition. Gotta house the sucker!
