Let me introduce you to Dr.Boogey
Started by electrictabs, January 17, 2005, 09:42:14 AM
RaceDriver205
Um, is there a guys head in that valve? (your avatar)
electrictabs
bancika
How could he fit inside mini tube  ???
Just kidding :)
tuckster
I tinkered around with madbeans Chunk Chunk layout. Maybe someone wants to use this:
Madbean Chunk Chunk (Dr. Boogie) with voltage doubler
http://forum.musikding.de/cpg/albums/userpics/24316/chunkchunkx4.pdf
- to be able to use 3 Pin PCB connectors for each pot. I moved the holes away from the caps. But you can't use 12 pin connectors only 3 pin.
- C20 has now 5mm contact spacing like C14.
- voltage doubler added (part list: http://forum.musikding.de/cpg/displayimage.php?pid=2792&fullsize=1)
