Radial Headbone
Started by macula56, January 22, 2005, 08:27:42 PM
macula56
does anyone know of a schematic for something like a Radial Headbone? it's a switcher that will let you switch between two amps but use the same cabinet. they are a bit on the pricey side so i'd like to build something along those same lines. anyone?? thanks as always. jmac
lovekraft0
http://www.aikenamps.com/HeadSwitch.pdf
Read and heed the warnings and cautions, or be prepared to toast something.  8)
macula56
thankyou gentlemen. excellent info.
The whole, entire secret to head switchers is to isolate the grounds with switching, never having them connected together, and to supply a load to the *unused* amp.
