WOW it works and it sounds GOOOD!!!!!!
Started by aron, January 30, 2005, 05:08:16 PM
WGTP
So, I guess you can chain 2 or 3 of these together like Joe's other ciruits, or do you need to use clipping diodes?   8)
Stomping Out Sparks & Flames
Joe Davisson
It sounds ok on it's own, so I guess you could chain them, but the circuit would get kinda ridiculous in size :) So far I've only tested out feedback-diodes, diodes-to-ground, and the first two shredmaster stages. The last one I definately want to build sometime, since I'm a gain freak :)
WGTP
I was thinking about the BlackCat Overdrive, that is just op amps with no clippers, or the single op amp Hot Cake.   8)
On of my  breadboards has a dual op amp with 3 sets of clipping diodes and you can easily do 4 sets.   :twisted:
