Hello all,
I've been lurking on this forum for quite a while now, but I just now got around to posting for the first time. I'm very new to stompbox building, and this site got me motivated enough to attempt my first solo build. I built the beginner project tonight, and it worked on the first try! Kudos to Aron for writing clear enough instructions that someone like myself (who just picked up a soldering iron for the first time) can make it work. Actually, saying that it works is a little bit of a misnomer. I cut to the chase and integrated a 3PDT into the pedal right away. I didn't have a 1k resistor, so I didn't wire the dead middle pin to 1k resistor to LED to sleeve. Now when I click the footswitch it's either active (boost working and sounding sweet BTW), or it's supposed to bypass, but no sound comes out. One thing that got me a little confused was the bottom 3 pins are labeled "varies with LED". Am I supposed to run any connections to/from them? RIght now, I just have the setup:
Input | +9v (on circuit board) | Output
Stereo Input tip | Nothing | Mono Output tip
Nothing | Nothing | Nothing
Could someone be kind enough to tell me what I might be missing?
Thanks in advance.
