simple capacitor queston
Started by school, April 24, 2005, 07:30:27 PM
school
call me stupid, but if there are no letters after a capacitor's numerical value, is it just a farad? if so, how does a farad compare to a microfarad (uf, right?).
HeaD
numerical value is expressed in pF
Sorry for my english :|
school
no, i mean, instead of .1pf, or .1uf, you just see .1 . what does that mean?
HeaD
Quote from: schoolno, i mean, instead of .1pf, or .1uf, you just see .1 . what does that mean?
maybe .1pF :)
MartyB
Here's a nice little tutorial on caps and designations:
http://www.kpsec.freeuk.com/components/capac.htm
In your example 0.1 is most likely 0.1 microfarads (0.1uF).  Unfortunately there are quite a few schemes for labelling values.  What type of cap do you have or need and/or what exactly are the markings on it?
Usually small ceramic caps that have only one or two digits are pF measurements.  The ones with three digits (in the absence of a n or u)  indicate picofarads, with the first two numbers being a value that is times a power of ten indicated by the third digit.  The components you will see/use will all be micro-, nano- or picofarads.
1 farad = 1,000,000 microfarads  (uF)
1 uF =  1000 nanofarads (nF)
1 nF = 1000 picofarads (pF).
HTH
MartyB
seanm
If you see .1 on a schematic it is *almost* always uF.
gammamu
Quote from: MartyB1 farad = 1000 microfarads  (uF)
1 uF  1000 nanofarads (nF)
HTH
MartyB
1F = 1000000uF
if it's not over-fixed, i can't use it for music.
school
alright, i'll just go with the assumption that it is uf, because the un-labeled values are: .001, .002, .02, and .003.  that sounds plausible that they're uf, right?
seanm
Quote from: schoolalright, i'll just go with the assumption that it is uf, because the un-labeled values are: .001, .002, .02, and .003.  that sounds plausible that they're uf, right?
Sounds like uF to me.
MartyB
:oops:
Yup!  1 farad = 1000 millifarads = 1,000,000 microfarads.
I
