opamp problems
Started by seanm, May 18, 2005, 02:50:40 PM
seanm
Last night I whumped up the front end of the Voodoo Labs Sparkle Drive. For the purposes of this problem, I only built the input buffer and a simplified first stage of the 4558.
FIXED: Fix shown in red. See  The Tone God's reply below
When I first started it, it would work. But then the output would die off. If I played a note I would get a staticy sound that would quickly die off.
The signal after the input buffer at pin 5 is always good. I tested all the caps but it made no difference. I then replaced the opamp with another new one. Same problem.
I then tried a TL072 and it worked.
Any ideas? My only thought is that the 4558 wants a stronger battery. The battery was at about 8.4 volts.
The Tone God
Just by looking at the circuit without the original schematic (which you should post a link to for more assitance) I would venture to say that you need to bias your input signal to 1/2 V+ after the cap (C2). Put a 100K or so resistor from 1/2 V+ to just after the cap (C2) right on the opamp input. Also make a habit of decoupling your output too.
Andrew
seanm
Quote from: The Tone GodJust by looking at the circuit without the original schematic (which you should post a link to for more assitance) I would venture to say that you need to bias your input signal to 1/2 V+ after the cap (C2). Put a 100K or so resistor from 1/2 V+ to just after the cap (C2) right on the opamp input. Also make a habit of decoupling your output too.
Andrew
Thanks :D I think you are right, I left too much out. The clean blend has a link to Vr. I like to build projects in stages. Usually it works, this time I screwed up!
Interesting that the TL072 worked though..... I think the TL072 has allowed me to get away with a lot of biasing errors.
I used an audio probe to test, so I had an implicit output decoupling cap.
Original schematic here: http://home.hetnet.nl/~chrisdus/download/VLSD.jpg
davebungo
What's the reason for using precise resistor values like 49.9K and 4.75K etc.  I've seen this in circuits before which I wouldn't have thought required such accuracy - is there a simple reason for using these?  Are these 0.1% or similar?
seanm
Quote from: davebungoWhat's the reason for using precise resistor values like 49.9K and 4.75K etc.  I've seen this in circuits before which I wouldn't have thought required such accuracy - is there a simple reason for using these?  Are these 0.1% or similar?
No 1% metal. 499k is a standard 1% value, 500k is not.
I used 5% resistors .... I am evil. Plus the 99k resistor used in the "fix" is actually a 100k. Easier to erase the 4 from 499k in the cut and paste :)
ninoman123
Well its probably...around a 100k...Resistor values arent always dead on...so even if you did use a 99k resistor, it prolly wouldnt even be that. Unless you bought some expensive precision resistors.
