MC33174 Quad Op amp
Started by MRX2099, May 30, 2005, 11:09:02 AM
MRX2099
I found a schematic and layout for a Echo-o-matic using a reel-to reel machine plus this pedal on a site here
http://www.moosapotamus.com/Echo-Matic_a.jpg
http://www.moosapotamus.com/Echo-Matic_b.jpg
but it uses a MC33174 Quad Op amp, will about any quad replace it in case I cannot find the 33174? are the pinouts on any quad op amp the same??
thanks
Transmogrifox
The MC33079 is a good replacement, and I have been able to order them from Mouser and Digikey.
Just about any quad opamp has the same pin-out, so you're pretty safe substituting anything that is rated above the power supply voltage that is being used in the circuit.
You're pretty safe using the old TL074, TL084, or NE... equivalent.
trans·mog·ri·fy
hrlz
that 12 year old link is wild now.
