Help! Problem building a looper/bypass switch
Started by ozzy, June 14, 2005, 05:19:30 AM
ozzy
If anyone can help me with drawings, what the best parts are to use etc. that would be great.
basically what i am biulding is a pedal with three switches, in input from a guitar, an output to an map, an output to a channel changer on an amp, an a send an return fo an FX loop.
Switch 1 goes to a 1/4 inch jack which controls the boost/channel change on my amp, it's an on/off switch and that bits pretty striaght forward!
Switch 2 controls the FX loop and adds in or removes it, or puts it inbetween the guitar and the amp, again this is pretty straight forward but I want to avoid any nasty clunks or ground loops.
Switch 3 is the bastard, this switch needs to reverse what ever the other two switches are doing, so I can turn switch 1 and 2 on at once or one switch on and one switch off....
i hope this is clear enough, any help would be much appreciated.
thanks, Ozzy.
niftydog
er, well I think you need to elaborate a bit more in order to get a response. But, there are already a lot of threads that discuss the whole switch pop issue, take the time to read through a few and be willing to experiement.
niftydog
Shrimp down the pants!!!
