Tube screamer only works at max
Started by moeburn, June 19, 2005, 10:32:22 PM
moeburn
Hey everyone, I just finish building this tube screamer on a breadbord:
http://www.generalguitargadgets.com/diagrams/ts-808_sc.gif
A couple mods: I added a third silicon diode (i'm using all 3 silicon) for the asymmetrical effect, and i replaced C8 with a jumper, because it was just sounding awful with C8 (tried 3 different caps, different types, same value, all sounded awful).  The chip is an LM358 and the transistors are 2SC1815.
When I turn the tone to full treble and the drive to max distortion, the thing sounds awesome, exactly like it should.  But if I try and get a less harsh distortion by turning the drive or tone down alot, all i get is clean guitar with the exact same harsh distortion on the hard notes.  If i play quietly, 0% distorted, if i play slightly louder, 100% distorted.
Is this a problem with the design of the circuit, or my parts, or should I be looking for a different pedal alltogether?
aron
QuoteThe chip is an LM386 and the transistors are 2SC1815.
Does it really work? The LM386 is the wrong chip. You need a dual op amp for that circuit. Like a JRC4558 or TL072.
moeburn
by LM386 i meant LM358.  I'll edit that.
seanm
Sounds like a bias problem. I would check that all points labeled Vr go to Vr, not to ground.
