Kearns892
Quote from: John Lyons on September 23, 2009, 07:43:40 PM
Less talk, more pics  ;D
Fairly straight forward OD I assume. Care to elaborate?
John Lyons
Actually it's a very non straight forward fuzz with a blend between one
and two transistors with a slight octave to give it
some nice edge and growl. I call it "Wildcat".
John
Basic Audio Pedals
www.basicaudio.net/
ocg
Quote from: Magnus on September 23, 2009, 07:36:49 AM
A pcb-comparison (original: left / cloned: right)
And a gutshot:
Greetings from germany
Magnus
nice work....hey magnus do you think you can share with me a copy of the PCB layout??.. :icon_redface: :icon_redface: :icon_redface:
...mojo is in your hands....
Nikolay
Dummy load
I use 16ohm/30W resistor and voltage divider using resistor and pot for recording.
I use small heatsink for resistors.
MarcoMike
beatuiful work as usual...
and how does it sound? I tried a resistors based power attenuator once (ok, it's not the same...:P) but the sound was kind of horrible... completely unbrightened....
Only those who attempt the absurd will achieve the impossible.
edd101
John, your accuracy always amazed me!
Ed
...it is always funny until someone gets hurt!!!
Kearns892
#10586
Quote from: John Lyons on September 23, 2009, 11:36:59 PM
John
Haha nice, and thanks for making me look like a fool  :). Sound clips?
Also a general question. Why do many builders place the power jacks on the side of the pedal as opposed to the back like most commercial pedals?
liveloveshare
my first build... byoc OD2.  learned quite a few things through the process. i bought it in february and put the circuit together but i took forever with the casing... but anyways, here's the beez kneez screamer.
davidallancole
Thats pretty sweet looking.
liveloveshare
#10589
Quote from: davidallancole on September 24, 2009, 08:33:14 PM
thanks. i had my artist friend draw the bees.  i kinda smeared it a little bit though... ah well.  live and learn.  next time I just need to be more patient with the coats of primer/paint/clear coat.  i didn't spend enough time with the primer so there's already quite a few chips.  but it sounds heavenly. :]
here's some more pics:
The French connection
Quote from: The French connection on September 23, 2009, 03:57:25 PM
Shorter wire to the switch i supposed. What i don't figure out is those who put the DC jack on the side...how do you plug it when you use a daisy chain?
Quote from: Kearns892 on September 24, 2009, 08:16:03 PM
It looks nobody wants to answer this one. :icon_razz:
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
salocin
Quote from: The French connection on September 24, 2009, 10:32:24 PM
It's a matter of layout convenience. If you have a look at John Lyons green pedal in the previous posts the pcb is mounted on top of the pots. If the DC jack were to be located at the top of the pedal this would be a lot harder to accomplish without having to move the pots further down the pedal.
musiclikscreams
Quote from: salocin on September 24, 2009, 10:49:21 PM
so u worry more about the aesthetics of the inside of a pedal rather than practical ease of use? ...doesn't quite make sense to me  ???
jacobyjd
#10593
Quote from: musiclikscreams on September 24, 2009, 11:32:03 PM
It's more a question of being able to fit it all in there. If I had my way, every pedal I made would have both I/O and DC jacks on the audience side of the box. That's just not possible in smaller builds if the PCB is too big, unless you make a crazy custom layout, which can be time prohibitive, as well as (possibly) more prone to failure.
edit: Also...'most commercial pedals'? Used anything made by MXR lately?
Kearns892
I know there are exceptions, I was wondering if there was a practicality on the user friendly side of things one way or the other that I wasnt seeing, but the logic of making it easier to wire makes complete sense to me.
jacobyjd
Quote from: Kearns892 on September 24, 2009, 11:47:52 PM
Gotcha...it's a tough balance to achieve, for sure.
musiclikscreams
Quote from: jacobyjd on September 24, 2009, 11:54:30 PM
i just realized that i dont bother puttin battery clips in anything i build... that makes a huge difference
i was wonderin y everyone was so worried about space haha
John Lyons
I put the DC jack there because it fits well there. Like it was mentioned. The board
mounts to the back of the pots and there is no room om the top vertical wal for the DC jack.
The board in the pic is small and still no room for the DC jack . Some boards almost run into
the jacks so I just put it by the Switch and it's nice and tidy there.
Case in point:
The Klon is a bitch to build! :'(
Basic Audio Pedals
www.basicaudio.net/
64fx
Sorry to keep showing pedals that I'm rehousing, but that's all I'm working on these days as far as pedals go...
Here's a rehoused Danelectro Cool Cat Transparent Overdrive.
snarblinge
seing as how this is the pics thread, here is another argument for dc jack positioning in 1000 words.
b.
snarblinge.tumblr.com
