g-sus
Quote from: mr.adambeck on September 28, 2009, 04:21:27 PM
Quote from: g-sus on September 27, 2009, 03:07:08 PM
Quote from: 1878 on September 27, 2009, 02:48:54 PM
How do you get the white lettering ?? Is it something skillful like airbrushing ??
I use a computer controlled vinyl cutter and white (or other color) vinyl, then application tape it to the pedal and clear coat.
Wow!  I love the Sho and the Burn!!!!  Where are you getting access to this vinyl cutter?  They are so good looking!
Work related :) That technique limits the type of graphics though..only simple vector art & text but that's the way I like it!
Insanekane
Thank you's goes to madbean for smaller layout  :D
Klontaur
Guts
Jaskalla todella komeita speduja  ;)
rousejeremy
Great etching!
Quote from: Insanekane on September 29, 2009, 07:28:13 AM
Klontaur
Guts
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
g-sus
Klontaur
Guts
Hyvältä näyttää Kane! I've been digging your work for some time now ;)
bean
Klontaur
That etch is superfly! I love how you left the swirls kinda aliased. Gives it some character  :)
octfrank
My current project, ugly but works  :)
Frank Thomson
Experimental Noize
Hupla
Completed builds: BSIAB2
Pedals to build: Dr.Boogey, TS-808
EARNEST
Looks a bit like Arduino :D
Dean Razorback V255 w/EMG 81/85 @18V -> Bugera 6262-212
DIY projects:
TS clone, in progress http://www.diystompboxes.com/smfforum/index.php?topic=78871.0
bigchasbroon
  The text included:
  SKRM−C8−R01 module, mono−in/mono−out
reverb and delay set
octfrank
Quote from: petemoore on September 30, 2009, 08:54:15 AM
  The text included:
It's an FV-1 based module, not officially released yet (so sales may not be happy I posted the picture, oh well). It will be available with different program sets, the mono reverb/delay set is the first one. Been working on it for weeks now (PCB design, program set code, example schematic) and just wanted to post something where other builders that can appreciate the time that goes into a new design can see it. The links in the post 2 posts under the picture are the preliminary data sheets for the module, program set and example schematic (as built in the photo).
Frank Thomson
Experimental Noize
juse
Quote from: kristoffereide on September 27, 2009, 06:11:50 PM
Quote from: roseblood11 on September 26, 2009, 06:27:52 PM
A D*A*M "Sonic Titan", hence the name. Great sounding pedal!
I used Mike Livesley´s veroboard layout.
The finish is inspired by "mills" (wire) and "cloudscapes" (resin coating).
But I´ll never try to put polyester resin on hammerite again - after 4 days it´s still sticky, I hope it will ever dry...
It takes glaze a few days to cure properly & it depends on the temperature as well... warmer temp=cures faster. It will feel rubbery for awhile, but cures up nice.
Should be done by now... how did it turn out?
roseblood11
Magnus
#10634
Hello,
QuoteOBW = Off Board Wiring!
Thank you ;)
QuoteWhat type of diodes is that in the original DOD pedal? Old blue-line japanese 1S???, or Schottkys?
Good question, I use 1N914 Silicon...
Quotehehe^^! Ich finde es nur unglaublich: Wie lange ist er schon dabei und entdeckt diesen Thread oder dieses Board erst jetzt? oO
Das Board kenne schon relativ lange, stimmt aber, ich poste wirklich ziemlich spät...
QuoteNaja, hat er aber wirklich schön gemacht.
Danke!
QuoteI wanted to tell you: zhat iz very nize wörk zhere Magnüz (I don't speak German) wizh zhe kabel
Thank you  :)
Quotenice work....hey magnus do you think you can share with me a copy of the PCB layout??.. icon_redface icon_redface icon_redface
I share the most of my layouts, but this one took a lot of time and its my little goodie - you know  ;)
@Jaco P.: Great etching-job!
@Kabi: Nice work too  :)
@roseblod: Super geworden!
The other's work is also great!
Here's the next one:
A Linear Power-Booster mounted in a plastic-toy-grenade:
Greetings
Magnus
AMZ Booster, Dist. +, DOD 250,
Dr. Boogey, Fuzz Face's, JCM800-Emu, LPB1,
May Booster, Obsidian, Orange T/B-Booster,
Pentaboost, Prof. Tweed, Rangemaster's,
SansAmp GT2, Superfly (Amp), Guv'nor,
Tone Bender MKI/MKII/MKIII, TS 808
Rawkgod
Quote from: Magnus on October 01, 2009, 05:51:46 AM
Hello,
Greetings
Magnus
Nice to meet you Magnus.
Super Awesome!
I wish I could think of a good pun right now.
Quote from: bioroids
Lol I think the only thing the Coca Cola doesn't do well is to relieve thirst!
jessetrbo
Good luck flying with that booster!  Pretty ingenious.
Jesse Trbovich
Jesse Trbovich -- Philadelphia
John Lyons
That pedal is "the bomb" how's that for a bad pun?
john
Basic Audio Pedals
www.basicaudio.net/
Magnus
#10638
Hello together,
QuoteNice to meet you Magnus.
Super Awesome!
Hi, nice to meet you too - and thanks  :)
QuoteGood luck flying with that booster!  Pretty ingenious.
Thank you  :icon_redface:
QuoteThat pedal is "the bomb" how's that for a bad pun?
Not bad  ;)
I really like your pedals John, they are over the top - inside and outside  ;)
So here's the next one, the legendary Dallas Arbiter Fuzz Face (Germanium)
I built from an own layout based on the original pcb (if you look at the partside).
It is built in a metal-enclousure I prepared with real-wood-veneer (bookmatched)
and has the following mods:
- Germanium/Hybrid (use of two Germanium-Transistors or Germanium/Silicon)
- Smooth/Rough ("Smooth": Germanium-Diode from Emitter to Base / "Rough": Normal, without Diode)
- additional Bass-Control
Greetings
Magnus
The French connection
#10639
You could use that switch instead...
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
