AudioMime
Quote from: free electron on March 06, 2010, 03:43:39 AM
Quote from: phector2004 on March 05, 2010, 03:31:59 PM
what is it??
and are those LEDs on a floating board? otherwise thats one hell of an optical illusion
It is a 1 sec looper/sampler/stutter/glitch pitch shifting pedal.
The LED daughterboard is attached to the pots using 9 vias:
Quote from: solderman on March 06, 2010, 03:19:04 AM
Really nice job. The layout i suprime. My guess a Dr Boogie with  Meeter LED:s  :o
Thanks. The leds are indicating one of the 8 working modes, like +/-1octave, reverse play etc...
:o :o :o :o :o :o :o :o :o
Could you give a name to this fair maiden? I would love to build one
AUDIO MIME
Quote from: rousejeremy
Stick the Tremulus Lune in a Feedback Loop and your neighbors will call the cops on you. Which will be awesome.
Valoosj
Quote from: AudioMime on March 07, 2010, 09:53:13 AM
what is it??
+1!
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
solderman
This ones digital right?
You both need the schematics AND the source code then ;D
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
Nitefly182
I wish I had started getting into decals sooner. I've been using them a lot lately and they look soo much better than anything I was doing before.
John Lyons
Those look sharp David!
Is that color laser on the red decal or inkjet decal?
The Copper hammer and TB fonts look real purdy.
John
Basic Audio Pedals
www.basicaudio.net/
Nitefly182
Its all inkjet. I have tried laserjet before and they looked like shit and were way too fragile. The inkjet ones look much nicer and because you clear them are much much sturdier.
meffcio
Inkjet? You're using a normal inkjet printer to do those? Anything more about that technique?
roseblood11
I use Laser-Decals, with the same results as Inkjet... Of course, the enclosure is clear-coated after applying the decals.
Magnus
#11849
Hello together,
here is my latest build, an Orange Treble and Bass-Booster based on an own PCB-Layout:
...and my TONE BENDER MKII PROFESSIONAL finally got new knobs, Chickenheads for sure - now it's also finished  ;)
Greetings from Germay
Magnus
AMZ Booster, Dist. +, DOD 250,
Dr. Boogey, Fuzz Face's, JCM800-Emu, LPB1,
May Booster, Obsidian, Orange T/B-Booster,
Pentaboost, Prof. Tweed, Rangemaster's,
SansAmp GT2, Superfly (Amp), Guv'nor,
Tone Bender MKI/MKII/MKIII, TS 808
knealebrown
Magnus, firstly very slick builds. congrats secondly are they little windows so you can display the transistors in the Mk 2 tonebender?  :D
if so nice idea, if not a little geeky  ;D
''99 problems but a glitch aint one!''
Magnus
Hello,
QuoteMagnus, firstly very slick builds. congrats
Thank you  :)
Quotesecondly are they little windows so you can display the transistors in the Mk 2 tonebender?  Cheesy
if so nice idea, if not a little geeky  Grin
Yes, you can see the polished germanium-transistors,
they are illuminated with 2 blue 3mm-Leds as you can see here:
http://www.diystompboxes.com/smfforum/index.php?topic=36392.msg655480#msg655480
Greetings
Magnus
phector2004
Quote from: Magnus on March 08, 2010, 11:21:35 AM
[/url]
How do you get your wires so stiff and neat? its like they're suspended in the air!
Taylor
It's not mine, but I'll venture a guess:
solid core wire+pliers+focus
Greg M.
Quote from: Taylor on March 08, 2010, 10:26:57 PM
Could this wire be the pre bond wire available at Small Bear?  I envy the neatness too and think I'll get some of this stuff for future builds.
Very nice pics from everyone.   ;D
Taylor
Yeah, you can get almost that rectilinear with the prebond, but it's not quite as stiff so it doesn't hang there as rigidly. I like it more than solid core, for sure. But my builds aren't quite that neat.
phector2004
i dunno I use solid core + pliers... i shape it up, put it all together, but it sags and the bends widen by the time im done soldering. Practice makes perfect, i guess?
Ronsonic
Quote from: phector2004 on March 08, 2010, 11:59:27 PM
Straightening the wire before bending it helps.
Easiest way to straighten is with a drill - take a length of wire, clamp one end to the bench, the other in the drill chuck, spin for some number of turns, reverse the drill and return. Straight wire.
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
Magnus
Hello,
thank you  :)
I do not use solid wire, I use braiding (hope this is translated correctly).
I think its more difficult using strong wire because it is not so flexible to shape.
I prepare the braiding with my fingernails, fingertip and a little tweezer  ;)
Greetings
Magnus
