Author Topic: Pictures!  (Read 10259574 times)
Ronsonic
Re: Pictures!
« Reply #13220 on: July 29, 2010, 01:11:03 AM »
Oops. would delete if I could.
« Last Edit: July 29, 2010, 01:12:53 AM by Ronsonic »
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
JKowalski
Re: Pictures!
« Reply #13221 on: July 29, 2010, 01:49:49 AM »
rns Generator with Quad Oscillators
Oh man that is awesome. I am loving that massive light on there.
And the controls, great layout! I love huge boxes with tons of controls, I can't explain it. It's just got so much... dunno, potential? Apparent versatility? Sheer tinker power?
kupfer_m
Re: Pictures!
« Reply #13222 on: July 29, 2010, 02:24:42 AM »
i have got to learn to etch...
Yes, I would say try it, it's fun. It's not that difficult. Buy some 1 or 2mm aluminum sheet to try on first to see what method works best for you.
Tons of good tips & hints here on the forum too.
kupfer_m
Re: Pictures!
« Reply #13223 on: July 29, 2010, 02:26:53 AM »
@ Kupfer_M
I use Photoshop CS4 for Illustation and selfmade Photoshop based templates.
I try to Finish all my pedals digital first.
So i can see wich Knobs fit the best, or how many space is left for my project in the enclosure.
Hi Camphausen,
That's what I use too. Do you design/draw the pictures yourself?
Zero
Re: Pictures!
« Reply #13224 on: July 29, 2010, 09:31:32 AM »
That's a cute box! Nice photo too.
Wow, looks sweet Zero!  Great idea to have it attached to your belt.. makes me want to do something like that too
I approve greatly! Would like to see a gut shot.
Thanks guys!
I haven't found a suitable belt clip or some other mechanism to attach to my guitar strap.  Any suggestions?
Gut shots have proven to be very hard to do... The inside of the box is extremely crammed, especially with the battery and all. Thecrappy phone cam doesn't help, either. This is the best I can do for you without disassembling the whole thing:
Steve Mavronis
Re: Pictures!
« Reply #13225 on: July 29, 2010, 10:04:01 AM »
Maybe take a steel belt clip off of a tape measure or find something similar to bolt on?
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
Re: Pictures!
« Reply #13226 on: July 29, 2010, 10:50:11 AM »
You can get a package of six belt clips here. http://www.leevalley.com/en/wood/page.aspx?p=32542&cat=1,42936,42452
dave
ghostsauce
Re: Pictures!
« Reply #13227 on: July 29, 2010, 11:07:40 AM »
It's not the prettiest solution, but I used to have a wireless unit and the belt clip was terrible and the chord was always in the way and looked weird.. so I just clipped it onto my strap near the guitar jack, and used electrical tape to secure it. It looked perfect cause the thing was black anyways, and because it was right beside the jack I just coiled up the extra cable and taped it too. Having it attached to the strap near the guitar was very comfortable and usable I found.. and it might be the solution for you too. But yours is blue so it wouldn't be pretty.. but I think you'll find that it is more usable on your strap anyways, and you probably would need some tape just to keep it there, even with a good clip. Certainly it would cut out a step or two when you strap into your guitar.
Hardcore Jesus freak
fluoreszenz
Re: Pictures!
« Reply #13228 on: July 29, 2010, 01:10:11 PM »
Preliminary tremolo build... and pushing the thread further to 666  :icon_evil:
At least it works fine, however the enclosure will be etched in the future but i need to gather some ideas for graphics first...
Magnus
Re: Pictures!
« Reply #13229 on: July 29, 2010, 02:07:58 PM »
Hello,
it is not a pedal, but it helps building them...
My "Geofex Leakage and hFe Checker"
(decal looks a bit out of place on photo, but it is not in real):
Gutshot (yes, a very large circuit!):
In action, measuring an OC70:
Greetings
Magnus
AMZ Booster, Dist. +, DOD 250,
Dr. Boogey, Fuzz Face's, JCM800-Emu, LPB1,
May Booster, Obsidian, Orange T/B-Booster,
Pentaboost, Prof. Tweed, Rangemaster's,
SansAmp GT2, Superfly (Amp), Guv'nor,
Tone Bender MKI/MKII/MKIII, TS 808
trad3mark
Re: Pictures!
« Reply #13230 on: July 29, 2010, 03:33:52 PM »
i can't remember if i posted my MicroAmp build before. I made it just before the 666 went up, and it was done with a TL071...
knealebrown
Re: Pictures!
« Reply #13231 on: July 29, 2010, 06:02:42 PM »
i was the 1000000 viewer. i have cemented myself in history  ;D
''99 problems but a glitch aint one!''
trad3mark
Re: Pictures!
« Reply #13232 on: July 29, 2010, 07:37:26 PM »
as per my earlier post, i'm not 100% sure if I posted this before, so apologies if i did. :)
So it's an MXR Microamp, but with a TL071. I did some research into it before I built it, as far as the TL071 goes, cos the Microamp uses something different. Can't remember off hand what it was... In anycase, the interweb suggested that a TL071 would actually give better results, cos it's generally a lower noise amp than the standard MA one. In anycase, i went with the TL071, and it is remarkably clean. My only problem with this build was that I couldn't get one of the Reverse Audio Taper pots without having to order it in online. I went with a linear taper. I know i could have used a 1M pot and some resistors, but the current pot is fine. So far, all i've been doing with it is leaving it on, at the set level i like, so it's grand.
The finish was actually done with tracing paper. I didn't have any spraymount either, so i used photomount. It's a little thicker, kinda like a light paste, and was a little messy. However, it gave a rather odd blotchy effect, which i kinda like! Makes it look a bit old or something. Anyway, it sounds great, and thats the main thing. This was also my second time mounting the pot to the board, to make everything a bit more stable, and it worked really well. I'm pleased with how it turned out in the end.
and the gibblets:
tubelectron
Re: Pictures!
« Reply #13233 on: July 30, 2010, 03:08:00 AM »
Hi Magnus,
Hello,
Good idea for boxing this simple device - I think it is better than the major part of the DMM and transistor-meters...
But I needed a more accurate instrument than this, with extended possibilities of checking for Ge Q's (variable Ib, Hfe, IceO, IcbO, IceS), so I had to buit it, as I didn't found anything interesting in commercial products :
A+!
I apologize for my approximative english writing and understanding !
http://guilhemamplification.jimdofree.com/
Camphausen
Re: Pictures!
« Reply #13234 on: July 30, 2010, 04:22:12 AM »
I work together with KMRFLMRN Illustration Colonge ( http://www.behance.net/kmrflmrn )
But most of my pedeals use different Pictures from other Artists. Sometimes if i have enough time i draw them myself.
cheers (:
trad3mark
Re: Pictures!
« Reply #13235 on: July 31, 2010, 07:57:09 AM »
 :icon_twisted:
  • Total likes: 123
  • Virtue signalling keyboard warrior since 2020.
    • frequencycentral
Re: Pictures!
« Reply #13236 on: July 31, 2010, 08:18:09 AM »
 ;D I waited for it to buffer before I realised..............
Re: Pictures!
« Reply #13237 on: July 31, 2010, 10:57:03 AM »
very  :icon_twisted:
ghostsauce
Re: Pictures!
« Reply #13238 on: July 31, 2010, 12:01:53 PM »
*copies gif*  >:)
Pigyboy
Re: Pictures!
« Reply #13239 on: July 31, 2010, 05:52:29 PM »
12AX7 Preamp named after my lovely wife
12vdc input 180v B+
Soundclips up soon
Soundclips at
 http://www.youtube.com/user/xtimehascomex#p/u/6/p3Hk7OOdnTY
And you'll have to admit, I'll be rich as shit
I'll just sit and grin, the money will roll right in....
                                                            - FANG
