G. Hoffman
Quote from: Jdansti on May 15, 2012, 02:44:04 PM
The jack goes where the end pin is. I've got a couple of acoustic electrics and you wouldn't know they were electric unless you look for the hole in the jack. My Martin has a trim pot installed just inside the sound hole near the low E string. It's easy to adjust. Here's a video of the jack installation:
That works fine, if your guitar has already got a pickup.  If you don't, a standard end pin's hole is too small for the jack and must be reamed out.  Please note, I did NOT say drilled out, but reamed out.  Trying to do it with a drill bit is an all but certain disaster.  And reamers are expensive, so you are probably best to have it done by a professional who already has the tool - it shouldn't be too expensive, as it is a quick and easy job.  It just really does require the correct tool.
Gabriel
Jdansti
Quote from: G. Hoffman on May 15, 2012, 07:43:21 PM
Gabriel
Thanks Gabriel. I agree. I had my Taylor done by a pro.
michelterres
Hi, this is my first post here, and I wanted to show a work I did for a friend last year, my friend bought a groovin compressor(which is actually a beta alvin compressor sold with another name) and didn't liked it, he asked if I could build a chorus inside of it, so I ripped off the insides of the compressor and used the tonepad layout for small clone with a digital bypass(drawn in corel draw), I also sanded the enclosure \m/
joethugs
Slade
Woolly Mammoth with input capacitor blending pot.
Really original 'design', as you can see ;D
Cheers.
Fernando.-
wavley
Slade, that truly is one of the most awesome things I've ever seen!!!
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
Colonel Angus
Can anybody link to build info for wooly mammoth? I just made our bass player a ROG Ginger and it is not fuzzy enough. Apparently I suck at searching today...
Quote from: frequencycentral on June 16, 2012, 12:59:15 PM
Why should you not have 90o angles? Do the electrons bunch up in the corners?
tasos
Quote from: Colonel Angus on May 18, 2012, 12:25:15 PM
Try madbeanpedals.com
rousejeremy
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
kato
Brian: Direct link to wooly mammoth pdf.
Slade, what's your over/fuzz mod?
If school won't teach you how to fight for what's needed
They're teaching you to go through life and get cheated.
Haddock
WOW!!! Slade, that's amazing!!!
Colonel Angus
Slade
Quote from: kato on May 18, 2012, 01:50:46 PM
Just a blending pot for the input capacitor.
In fact, besides this mod it might need a mix balance pot, to avoid bass loss, but it sounds really good as it is right now.
Magnus
#19413
Hello,
wow, this is a beauty of a pedal, Slade  8)
...but why the hell is that diode blue and not orange as the amp-manufacturers-name? (or is this the ironic fun of it maybe?)
Greetings
Magnus
AMZ Booster, Dist. +, DOD 250,
Dr. Boogey, Fuzz Face's, JCM800-Emu, LPB1,
May Booster, Obsidian, Orange T/B-Booster,
Pentaboost, Prof. Tweed, Rangemaster's,
SansAmp GT2, Superfly (Amp), Guv'nor,
Tone Bender MKI/MKII/MKIII, TS 808
artifus
the led looks yellow/orange in the off state to me. i suspect digital camera ir/uv light exposure shenanigans.
Slade
#19415
It's white!
And here's a sample with guitar: http://dl.dropbox.com/u/3565959/Pajuan%20Woolly%20Mammoth.mp3
Until minute 2.33 the OVER/FUZZ control is at max (so it's like a stock woolly mammoth) and then it goes to minimum to get some overdrive, or "not so fat" sounds.
Earthscum
Quote from: Slade on May 18, 2012, 04:01:51 PM
It's white!
Jeez... get all racist about it...  :icon_lol:
That is a nice box, very kewl! Honestly, all the "orange" tinted lense LED's look green to me when they are on. My new vid camera has an "orange to green" charge indicator. I just leave it in overnight because I can't tell if it's charged or not. I kind of wonder if that has to do with my "color ignorance" (apparently it's a funky connection between my eyes and brain that certain colors don't register the same. I don't immediately register red light, but I can pick out shades of stuff like camouflage like it's a red light. Fluorescent orange and pink register as the same color until I see them next to each other. I used to do all my art in B&W because of it, lol).
Pyr0
Hi all,
ok after a few months of sourcing components, building, debuging, calibrating etc, my moosapotamus MN3007 based A/DA flanger is finally finished, and it sounds sweet.
And yes, I built it on veroboard, thanks to Harald from sabrotone. I won't ever attempt anything this complex on vero again, it's just too painful and prone to errors.
rousejeremy
Looks fantastic! I've had a few "never again" moments with vero as well. I can't imagine the hell you went through debugging all THAT.
Pyr0
Thanks. I also added a little LT1054 based charge pump voltage doubler so it can be powered from a regular 9v supply. That's the board on bottom right. The LT1054 can supply up to 100mA, so it can handle this pedal no problem, current draw varies between 25mA and 38mA as the LFO does it's business.
