Author Topic: Pictures!  (Read 11650834 times)
Magnus
Re: Pictures!
« Reply #12800 on: June 22, 2010, 07:48:50 AM »
Hello together,
Very tidy magnus, showing us some of that famous german precission  ;)
Thank you  :)
Your looper is awesome too, really good (Moog-like) looking - nice work!!!
Hi Magnus,
Your Tone-Bender is very nice - I particularly appreciate that "golden gentle sparkle finish" and the jewel pilot.
Thank you  :)
I would have done the same on my Double-Tone-Bender if I knew how to do it simply with success, but...
It is not very difficult, you just have to try different color and clearcoat-manufacturer  ;)
As you can see I used plexiglas to cover the PC designed and printed faceplate
Your Tone Bender Dual-Pedal is great, I like the look and the wiring-job inside very much!
Have you soldered the transistors?
So how have you done the simple but nice finish of your Tone-Bender ?
- was the box already painted ?
- is the lettering PC designed and printed on a transparent adhesive foil ?
- How in the world do you make it... DURABLE and ABUSE RESISTANT Huh
Thanks for your informations - I am a paint unsuccessful newbie !
I painted the enclosure myself like I always do...
First I grind the enclosure with sand-paper, then I add primer and let it dry, then I add some paint till it is dry,
then some more paint and if it is completely dry I add a self-designed waterslide-decal and the last finish is clear-coat.
It is very durable if you don't kick it with a football-shoe  ;D
Greetings
Magnus
« Last Edit: June 22, 2010, 07:50:56 AM by Magnus »
AMZ Booster, Dist. +, DOD 250,
Dr. Boogey, Fuzz Face's, JCM800-Emu, LPB1,
May Booster, Obsidian, Orange T/B-Booster,
Pentaboost, Prof. Tweed, Rangemaster's,
SansAmp GT2, Superfly (Amp), Guv'nor,
Tone Bender MKI/MKII/MKIII, TS 808
Re: Pictures!
« Reply #12801 on: June 22, 2010, 09:38:21 AM »
HOW DO YOU PUT A NON- SET SCREW KNOB TO A SMOOTH POTENTIOMETER WITHOUT GLUING OR PUTTING IT PERMANENTLY.  like putting some adhesives to hold it strong enough, but can still be removed if needed.
I've done this with knobs designed for ribbed pots. Just get a drill bit and ream out the knob to cut back the ribs a bit, then smack it on to the pot. The ones I've done like this are plenty solid enough, but you can lever them off with a screwdriver or something if you need to remove them.
and before anyone else says it knobs, ribs etc Ohhherrr MIssus!
tubelectron
Re: Pictures!
« Reply #12802 on: June 22, 2010, 06:28:17 PM »
Hi Magnus & thanks for your answer,
Yes, the Ge transistors are soldered.
So it is all self-made. I would be interested to know the brands / the kind of the products you have used here, for the decal and for the painting job. I would be glad to do something else than plexiglas...
A+!
http://guilhemamplification.jimdofree.com/
kungpow79
Re: Pictures!
« Reply #12803 on: June 22, 2010, 06:30:55 PM »
brilliant paint job how did you get that?? is it an airbrush?
Actually, its a PPP enclosure, a "blem" no less.  I wish I could make it look that good myself, but I did take the pictures! ;)
a soBer Newt
Re: Pictures!
« Reply #12804 on: June 22, 2010, 09:12:48 PM »
SHOCLONE
Guts
FuzzFactoryClone
Guts
Re: Pictures!
« Reply #12805 on: June 23, 2010, 03:50:10 AM »
SHOCLONE
your gonna get some ribbing about  them wonky pots!...lol...only joking.. :icon_mrgreen:
:P ::) :o :-[ :icon_lol:  :icon_rolleyes:
Hides-His-Eyes
Re: Pictures!
« Reply #12806 on: June 23, 2010, 04:52:10 AM »
As a fellow DIYer without a drill press I have nothing but sympathy
Re: Pictures!
« Reply #12807 on: June 23, 2010, 04:58:31 AM »
yeah mee too..i havent a drill press..just a kitchen floor and a bit of wood and a foot....lol...
darron
Re: Pictures!
« Reply #12808 on: June 23, 2010, 05:26:08 AM »
invest in a centre (center if american) punch and a steel block (:
couple that with a sharp pilot hole drill bit.
Re: Pictures!
« Reply #12809 on: June 23, 2010, 05:50:58 AM »
yeah i always centre punch then do  a 1mm hole then open the top of the hole with a 3mm...(countersunk sort of)..
with a cheap version of a dremel...
no slipping when it comes to the 7mm etc with power drill......bang on everytime..but yeah i'd love a press...
no room in a poxy 1 bed flat though ha ha ha... :icon_rolleyes: :icon_rolleyes: :icon_rolleyes: :icon_rolleyes: :icon_rolleyes:
Magnus
Re: Pictures!
« Reply #12810 on: June 23, 2010, 05:51:22 AM »
Hello,
A+!
The color is from "Faust", i buy it in a local home-improvement-market, it is color with solvent...
I buy my primer in a colourstore for cars, it is high-quality primer for aluminium,
the manufacturer is "roberlo" (ISOFAST 1K MEDIUM Fondo).
I use waterslide-decals for Inkjet in clear,
on the back of those decals are some printed words: "Inkjet/Clear waterslide decal paper"
I hope I can help you a little bit, but it seems that you have to look for similar products in your country...
Sorry if my english is not correct at all, I tried to translate it  ;D
Me too, I drill everything with hand, but it is important to drill with a small drill first, then with a step-drill...
Greetings
Magnus
« Last Edit: June 23, 2010, 05:58:48 AM by Magnus »
arma61
Re: Pictures!
« Reply #12811 on: June 23, 2010, 06:41:43 AM »
Nah!!
you guys don't understand what's back on a different distanced pots, they are the most used pots, so the distance is big enough for either our big thumb, so we dont turn the other pots accidentally, or ever turn those pots with our feet while plaiyng!
  :D :D :D :D
NB posted by who has a (cheeeaaap) drill press and still is not able to make 5 holes in a straight line and at the same distance!!!!!)   ;D ;D ;D ;D ;D
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
darron
Re: Pictures!
« Reply #12812 on: June 23, 2010, 06:54:26 AM »
just made some red/silver PCBs for a friend and was sending him the photo.... couldn't help but crack up looking at myself so i must post it here...
keto
Re: Pictures!
« Reply #12813 on: June 23, 2010, 12:29:17 PM »
Finished up a couple yesterday...
Hides-His-Eyes
Re: Pictures!
« Reply #12814 on: June 23, 2010, 02:09:10 PM »
First pedal I've ever fully boxed up and had working- a present for my best mate's 21st. Took me about 10 hours including breadboarding it but he's going to love it...
knealebrown
Re: Pictures!
« Reply #12815 on: June 23, 2010, 03:39:49 PM »
Sweet man, I did the same with my first pedal. Congrats to you and congrats to him for surviving this crazy world for 21 years. But......what is it?
''99 problems but a glitch aint one!''
Hides-His-Eyes
Re: Pictures!
« Reply #12816 on: June 23, 2010, 03:56:40 PM »
It's a Timmy clone I adapted for bass with some cap changes :)
Galego
Re: Pictures!
« Reply #12817 on: June 23, 2010, 05:22:25 PM »
My attempt at giving a professional presentation to a build i was asked to do. My first commercial build. :)
Steve Mavronis
Re: Pictures!
« Reply #12819 on: June 23, 2010, 10:48:17 PM »
You succeeded very well. It definitely looks professional for sure. Good job!
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
