OC44's "tested" and "cheap" on EBAY !!!-UPDATE-
Started by MartyMart, October 19, 2005, 03:43:13 AM
barret77
oh my god, the little metal tab indicates the emitter?
@!$@!#$!$#@^%^ !!!  :icon_eek:  :icon_eek:  :icon_cry:
I thought that since the red dot marks the collector on all oc44, the metal tab indicated the collector as well...
That's why the circuit wasn't working! I was thinking that I needed a different boost to bias it properly... dang!
Have I destroyed mine oc44 by this dumb mistake? Can the emitter/collector inversion damage the transistor?
MartyMart
Quote from: barret77 on October 28, 2005, 09:31:45 AM
As far as I understand .... NO  :D
I have reversed a LOT of trannies and have only damaged 1, which was a 2N7000 FET anyway !
Quite often they will "work" the wrong way around, but just sound quiet/biased badly.
Just dont leave it in there for toooo long ..  !!
I use sockets 100% of the time, and you are WAY more likely to damage them with too much
HEAT ... if not socketted/soldering direct
Marty.
barret77
pheew...
I'll try again tonight... desperate moments here :)
thanks Marty
chrishopkins
I tested mine by plugging it into my multimeter and testing the HFE.
Got that worked out - on with the breadboarding!
