3 or 4 octave up square wave ??
Started by markusw, November 04, 2005, 06:48:58 AM
markusw
OK, this is what I came up with so far. The 1/2 sawtooth oscillator is stolen from the Ring Stinger's VCO (including Q5 and Q6). C5 was increased to fit the bass frequency range.
So far all results are just from simulations. The circuit is fed directly with a 0/12V 50:50 square wave.
Although the circuit seems to work, the sawtooth wave's amplitude unfortunately gets smaller with increasing frequency since c5 is charged less and less with increasing frequency. Thus, adding the square wave to the sawtooth does result in an octave up sawtooth only at the lowest frequency I tweaked the circuit for (31 Hz). The output after the final comparator is a nice octave up square but only for 31 Hz.
At the moment I don't have any idea how to avoid the sawtooth amplitude drop with increasing frequency.
Any comments are highly appreciated :)
Regards,
Markus
gez
#161
I finally understand what Mr Funk-On was mooting (thanks), and my understanding is you'll need some sort of feedback/auto-gain circuit to keep amplitude of the sawtooth stable...though I should imagine, as with most side chains, there'll still be a slight delay.  Probably not noticeable with one octave up, but perhaps it will be with the amount of octaves you're aiming for?
TELEFUNKON
like in a lowpass, the voltage that charges a cap through a resistor sinks at the resistor/cap node
with rising frequency;
take care, that the charging voltage increases, as the frequency rises.
There was an article once, in a european electronics magazine for constant sawtooth from square, 28 years ago.
(there`s another way also).
A.S.P.
what`s that talk about the rumour of a new proprietary wavebending disto-chip?
Analogue Signal Processing
PacoPicoPiedra
