Author Topic: Tap timing, hideously complex?  (Read 9587 times)
Vsat
Re: Tap timing, hideously complex?
« Reply #20 on: December 08, 2005, 05:57:32 PM »
Yup, this thread was getting sidetracked into a "Generic Interface Module" thread. Certainly a good idea to build up a application library for your favorite uC, and pick and choose as req'd. If someone was offering a pre-programmed PIC  as a general-purpose tap tempo controller/LFO then it would make sense to include several  output and interface options, otherwise, program specifically for the intended usage.
A "two-transistor autowah" circuit hooked up to a uC might seem like going overboard, but completely new functions could be incorporated  (and selected/modified/added)  quite easily, as long as you have the programming tools, without adding a lot of circuitry... just a few extra switches on the panel.
Cheers, Mike
Transmogrifox
« Reply #21 on: December 08, 2005, 08:19:57 PM »
Transmogrifox,
If you use an opamp "polarity reverser" like
http://www.geofex.com/Article_Folders/polarity_reverser/polarity_reverser.htm
(I think there's a similar circuit in one of the Craig Anderton's books)
You can control the switch with a PWM for a range of -1 .. +1.
Doh!  Thanks GFR!  I'm doing this in a much more complicated way than necessary.  I'm using 2 opamps with one inverting the signal then arranging the CMOS switches in a "Pot" like configuration.  It works well, but I may be able to decrease the number of op-amps by using this simple technique.  Due to the op-amp's slewing capability, it may be necessary to do all the 100kHz PWM carrier filtering before the opamp's + terminal to make sure the slewing isn't causing distortion.  This is just as easy as using a few passives all the same.
trans·mog·ri·fy
A.S.P.
« Reply #22 on: December 09, 2005, 07:21:24 AM »
here`s another nice "reverser", continuously controllable by a single variable resistor to ground... :
http://www.pat2pdf.org/patents/pat3633005.pdf
Analogue Signal Processing
