Author Topic: ZVEX Pedals  (Read 1604 times)
jbm222
ZVEX Pedals
« on: December 19, 2005, 02:25:54 PM »
Does anybody know how a ZVEX machine works?  I sounds pretty interesting, but not like something I would use often enough to spend that much money for one.  So does anybody know how it works and/or where i can find a DIY pedal that does the same thing?
Also, does anyone know what he uses for the timing generator and switching mechanism he uses for the Seek-Trem & Seek-wah?  It seems like the would work by having a single filter with probably a few CD4066 to switch the pots in and out, then another timing chip that generates sequential control signals to switch the switches.  But what does he use for a variable rate low frequency timing generator?
smashinator
Re: ZVEX Pedals
« Reply #1 on: December 19, 2005, 03:00:15 PM »
 It seems to me that the Machine generates crossover distortion, with some filtering(?).  So basically, make a small class AB amplifier, then break it.   ;D  ***EDIT**** I meant Class B amplifier.  ***end edit***
There's a project (on GEOFEX?) that is a sequential stepper you could use to do something like a seek-whatever.  I can't remember what it's called.
« Last Edit: December 19, 2005, 03:01:47 PM by smashinator »
People who say it cannot be done should not interrupt those who are doing it. - George Bernard Shaw
http://pizzacrusade.blogspot.com/
Lurco
Re: ZVEX Pedals
« Reply #2 on: December 19, 2005, 03:09:35 PM »
just sneeked in to ask, after knowing Z is sitting on a plane, not being able to monitor?
new ZVEX secrets
Paul Marossy
Re: ZVEX Pedals
« Reply #3 on: December 19, 2005, 03:50:09 PM »
I believe that Zachary mentions the use of crossover distortion in the demo video. I am quite intrigued with that particular offering of Z. Vex Effects.
The Tone God
Re: ZVEX Pedals
« Reply #4 on: December 19, 2005, 04:20:32 PM »
As always the function is your friend.
For your first inquiry search for things like "crossover". Here's one little tidbit I found which may be interesting:
http://www.diystompboxes.com/smfforum/index.php?topic=37057.0
As for Seek/Ooh-like devices look up "The Vanishing Point".
Andrew
« Last Edit: December 19, 2005, 04:22:35 PM by The Tone God »
