Femtoverb /Wavefrontsemi/: replacement encoder?
Started by MetalGuy, January 31, 2006, 07:10:09 PM
MetalGuy
I would like to build the Femtoverb but I noticed that Allied don't have in stock the encoder from the schematic . I did some search  for 16 pos. gray code encoder at Digikey.com - they carry several types. Can somebody advise which of them would be suitable for Femtoverb?
Thanks in advance!
Peter Snowberg
Any switch that puts out a 4 bit Grey code will work fine. You can also use any 4 bit hexadecimal coded switch; the only difference will be the order of the algorithms selected. Sorry I don't have time to research. If you post a link to a switch you're thinking of I can tell you if it'll work.
Good luck! The DRE is a really cool chip! 8)
Eschew paradigm obfuscation
MetalGuy
How about this CTS one for example?
http://rocky.digikey.com/WebLib/CTS/Web%20Data/288%20Series.pdf
Also can you change effects parameters in that chip and how or everything is preset ?
Why wouldn't a quartet of toggle switches work?  All it involves is 4 bits to set appropriately, right?
MR COFFEE
Calling Steve Daniels,
This would be a great chip for Small Bear to sell!!!!!!!!!!
I'd want an encoder. It'd be SOOOOO much easier to know what I was telling the chip to do than 4 toggle switches. IMHO.
Bart
Peter Snowberg
Quote from: MetalGuy on January 31, 2006, 07:58:09 PM
Perfect match. 8) (that may be the same one used in the Alesis Picoverb)
You can only change which algorithm you're running. No internal effects parameters are available. The Mix control between the wet and dry outs is as much as you get. Some of the algorithms are less useful without LFO control, but the verbs sounds good.
Toggles? Sure. 4 toggles will work just fine.  :)
The Tone God
Quote from: Mark Hammer on January 31, 2006, 08:19:16 PM
My first modem was just that. Before that I had make beeping noises into the phone.
Andrew
MR COFFEE
Hey Andrew,
QuoteMy first modem was just that. Before that I had make beeping noises into the phone.
Now that is f*cking funniest thing I'veheard all week. :icon_lol: :icon_lol: :icon_lol:
Thanks, I needed that!!!!!!!!!!
Bart
The Tone God
MetalGuy
QuoteCalling Steve Daniels,
