Gez, what programming language are you using?
Phil, I'm using Assembly (most textbooks use it so there's not much choice).
Initially there were only a handful of things I wanted to learn - the most pressing being stepped LFOs, which I've covered now - but, as always, once you understand what these things can do then more uses spring to mind.
I don't have any chips to play around with, let alone a programmer, so don't know if any of my programs will work yet...soon find out (gulp)!
