Author Topic: Arrgg, another dumb question  (Read 1271 times)
rbcguitar
« on: February 16, 2006, 12:46:37 AM »
Can anyone help.
I got a 3pdt switch, which connectors are which? I got the tawain blue one
RBC
BrianJ
Re: Arrgg, another dumb question
« Reply #1 on: February 16, 2006, 12:49:45 AM »
Looking at the bottom, with the terminals horizontal, the columns are the individual switches.  The middle (vertically) is the common.
rbcguitar
« Reply #2 on: February 16, 2006, 12:52:20 AM »
They are all in same direction, I guess I dont understand
343 Salty Beans
« Reply #3 on: February 16, 2006, 12:53:05 AM »
And here's a picture, too!
I'm one of those people that needs a visual.
rbcguitar
« Reply #4 on: February 16, 2006, 12:56:33 AM »
sorry, just 1 more dumb question, does it matter which way u hold it, because the way i see it u have 2 choices. which way is up?
343 Salty Beans
« Reply #5 on: February 16, 2006, 01:05:58 AM »
Nah, it doesn't matter...not on a footswitch, anyways. on a toggle, rocker or slide switch (or something where you can TELL which positions are which just by looking), if you wanted a certain switch position (up=on, down=off) then you'd worry about it.
The way a switch works is that the middle poles (the middle row) is the common. On a Double Throw switch, this is always the case...no matter which position your switch is in, it will always have a connection. That's why your input and output jacks are connected there...so signal is always carrying through. The OUTER rows of poles are what make the switch work...when the switch is one way, you're going to be touching one set of the poles, the other way, you'll be touching the OTHER outer set. On a footswitch, it's pretty much inconsequential...unless you've got OCD and want to wire every switch the exact same way  ;)
Don't worry about the questions....it's how you get started. This isn't a forum where every newb gets flamed...only the SUPER-dumb ones that post a thread if they so much as fart.
Peter Snowberg
« Reply #6 on: February 16, 2006, 02:48:13 AM »
questions are good.  :icon_biggrin:
If you have questions about what connects to what, grab a piece of paper and a pencil along with a meter. Draw the connections you want to trace out (the back of the switch in this case), and check each set of connections with the meter until you know what terminals connect to what terminals. click the switch and check it out again.  :icon_wink:
Eschew paradigm obfuscation
bwanasonic
« Reply #7 on: February 16, 2006, 02:54:24 AM »
I use an alternate wiring, from GeneralGuitarGadgets:
http://www.generalguitargadgets.com/diagrams/bsiab_2_lo.gif
Only because it's the first one I found when I started building - not sure if either scheme offers better performance in practice.
Kerry M
twabelljr
« Reply #8 on: February 16, 2006, 01:06:20 PM »
Here is another illustration with input and output jacks, and a LED. Battery and circuit board also.
http://www.diystompboxes.com/beginner/circswled.jpg
Shine On !!!
scaesic
« Reply #9 on: February 16, 2006, 02:29:17 PM »
taking the first veritcal row
__
__                                _______    top
__    =          ________/                 middle
                                   _______     bottom
it just connects the middle terminal to either the top of the bottom terminal, on a 3pdt there are just 3 vertical rows which are all thrown simultanously
nelson
« Reply #10 on: February 16, 2006, 02:42:53 PM »
I wire it up like a DPDT for the signal switching and an SPDT for the LED.
the left being the DPDT and right being SPDT.
There are loads of ways to wire up a 3PDT.
It helps to know how the switch works inside, then you can wire it up any way that works.
This is in the beginner forum right at the top as a sticky.
It helps if you try to read the resources available before posting.
My project site
Winner of Mar 2009 FX-X
