Bad Stone Question for Zero
Started by RaceDriver205, March 03, 2006, 01:55:06 AM
RaceDriver205
I have recently built the bad stone, but it does not phase/oscillate. It mearley outputs the unaffected guitar signal.
You have said that you have built it from your own layout (which I have also done), and yours works.
But there must be something different between yours and mine coz mine doesnt work. I have checked all of the connections and traces, and polaritys etc and theyre all correct.
Do the pink lines on your layout mean connect the pads with a wire? (coz thats what i did).
If you can think of any slight changes you did to yours or anything, or why it is mine doesnt phase that would be great.
(None of the other threads were any help).
Zero the hero
It seems that this is a common issue which affected many builders...
Yes, pink lines are meant to be jumpers and shuold be connected with a piece of wire.
Does the manual phasing works (you should hear phasing sound moving the "manual shift" pot)?
RaceDriver205
I have not connected a manual shift control (i only need to as an auto).
Any idea what might be different about yours?
