Author Topic: In the spirit of the new forum area...Here's some code  (Read 10974 times)
Peter Snowberg
Re: In the spirit of the new forum area...Here's some code
« Reply #20 on: March 06, 2006, 01:06:30 PM »
It does add up and PICs are quick so a little more math isn't much of a problem.
Meta-code for average of 4 numbers:
load value1
add value2
add value3
add value4
shift right
shift right
save result
If you're playing in 11/17 or some other timing, the code gets a little more tricky.  :icon_wink:
Eschew paradigm obfuscation
Dave_B
« Reply #21 on: March 06, 2006, 01:17:03 PM »
That's what I was doing when my programmer went belly up.  Two shifts to the right.  The only difference is that I was using the 16-bit timer and ignoring all but the first and fourth switch closures (as I mentioned earlier).
Help build our Wiki!
Transmogrifox
« Reply #22 on: March 06, 2006, 04:28:36 PM »
load value1
add value2
add value3
add value4
shift right
shift right
save result
Since we don't have any 16-bit registers we may want to do something like this:
load value1
load value2
shift right value1
shift right value2
add 2 results, store in A
load value3
load value4
shift right value3
shift right value4
add results, store in B
load valueA
load valueB
shift right valueA
shift right valueB
add results, store in result register
...or we could keep track of an extra register per byte for carries
...or we could keep track of the non-zero 2-1 bits that shift off the end and add 1 to the final result if there is a pair generated...or just add 1 to the result if there is a non-zero 2-1 bit at any point in the operation.
I think the being off by 1 will be inconsequential.  We would perceive a phase lag rather than a tempo change if the musicians kept perfect tempo in the song, but usually we (speaking for myself mostly) don't keep to that degree of precision where our technology would be at fault for getting us out of sync.  We would need better than 8-bit processing if we were that good.
trans·mog·ri·fy
