As some of you know, I've been working on a pedal based on the preamp from the Korg SDD-3000. The pedal will be called the Triad, and it features three stages. They can be preamp (from unity to boost), second boost stage, and third boost stage, or preamp, series/parallel fx loop, and third boost stage. Both the second and third stages have their own footswitches and adjustable levels, and the third boost stage has a dedicated tone control. The second stage, when using a delay in the fx loop, offers delay trails.
The pedal takes 9vac but has a 2.1mm 9.6vdc output that can power up to 900ma worth of daisy chained 9vdc tip negative effects.
Here are some photos:
Still gotta even out the three LED levels. The connected delay is powered by the Triad's 9.6vdc output.
The first prototype is on the right - it lacked the tone control which is needed with some amps when the Boost is cranked.
On the first prototype I ordered the wrong pushbutton switches (they come out too far) and on the second Digikey shipped the wrong pushbutton caps.
A tight fit! Those are the 3PDT switches that Aron sells and I haven't had any problem with them at all. Thanks, man!
