Author Topic: DIY Layout Creator - software for easy drawing PCB, vero and perfboard layouts  (Read 1001348 times)
alparent
Re: DIY Layout Creator - software for easy drawing PCB, vero and perfboard layouts
« Reply #1460 on: February 11, 2009, 10:54:35 AM »
Just a little question for bancika.
Why is you application setup trying to change my IE settings?
McAfee is picking it up and won't allow it.
bancika
« Reply #1461 on: February 17, 2009, 11:38:25 AM »
Hmm, it doesn't mess with IE or anything else in the system...check that file is not infected with a virus or something.
bancika
by the way, I changed my domain from storm-software.co.yu/diy to diy-fever.com, if some link doesn't work just replace the first part and it should be ok
Cheers
kristoffereide
I'm having problems with your software. It says "No active document", and won't allow me to do anything...
I find it funny how I can have close to 1000 components, yet I never seem to have enough parts to make a project. :icon_eek:
Barcode80
me too. i couldve sworn someone said it worked in vista, but the original won't work. I would use the new one, but every time I try to move the end of a trace if i accidentally touch a component the component comes with. no good for me.
kldguitar
we commonly use protel . it is good software to design pcb and schematic.if some want, please send email to me. I send it by mailbigfile
ianmgull
Settings> Uncheck "Sticky Points" ;-)
bside2234
Or hold down shift while you move components. :icon_wink:
J-Bones
Hey Bancika,
I'm just getting started with pedal building and thought I'd give this program a shot.  Man, I'm glad I did!  I used it to layout a selectable frequency booster circuit and had no problems.  I'm lovin' it!
The rest of my parts should be here on Monday.  Now, if the actual build goes that smooth, I'll be very happy.    :D
"Everybody is so talented nowadays that the only people I care to honor as deserving of real distinction are those who remain in obscurity."  Thomas Hardy, 19th Century English novelist.
kristoffereide
to all of you that can't run this program... right click and runs as admin, I figured it out a week ago...
only have to do it the first time
JFX09
Hello,
I have downloaded the programm and I'm getting my head around it and I have to say that so far, it's fantastic, very easy to use (the multi-platform version)
But I have a little problem,. When I select print, it prints a blank page. I'm sure it must be some easy thing to solve, but I can't figure it out, sorry.
Any help will be greatly aprreciated. By the way I'm trying to print a simple pcb, solder pads and traces, nothing complicated.
thanks in advance.
jf
edit: I apologise in advance if this problem has been adreessed before, I could't find an answer usin search.
Happiness is a effin' hot soldering iron
kristoffereide
click "render image" and print the image
JFX09
I take it you mean export image? I'm using V. 2.0.1. multi-platform.
I tried that (export img to png and then printing it with paint) but it's way too big. How do I get it to the right size?
thanks a lot
jf
imcdermott
I'm new to the forum and haven't figured out if i can search within a thread. So sorry if this has already been asked. But I'm new to pedal building and was checking out your program. I downloaded the beta2 version (i'm a mac user) and i can't open any of the files on your website. Is there something I have to do first? Thanks! And again, sorry If this has been answered.
Ian
bside2234
You have to save the file to your hard drive. Open DIY Layout Creator and then open the file from the program.
Barcode80
actually, most of those layout files are in the old program format and as mentioned earlier in the thread, they cannot be opened within the new version.
bside2234
You're right. I forgot about that.
Johnnie D.
There was a guy who had the same problem as me but I didn't see where there was an answer to the file format not recognized when trying to open diy files from the program in xp.
Any suggestions will be greatly appreciated.
Johnnie D.
O.K. Sorry for taking up space. I downloaded and installed the windows version only and it opens the files.
Thank you.
Elektrojänis
Cheers
Probably because of the domain change, the update library in help setting gives this error: java.net.UnknownHostException: www.storm-software.co.yu
I don't know if there is anything to update really (I just downloaded the latest multi platform version a few days ago), but I just thought to report it...
