Yet Another Dr. Boogey Build Report(w/sample)
Started by RDV, May 11, 2006, 11:55:16 PM
RDV
I put the Dr. Boogey together tonight in a marathon 5 hour session. It was a bit tedious wiring 6 pots but boy was it worth it. This is the best sounding high-gain DIY distortion yet. I'm not sure you could make it better unless a footswitchable cleaner sound could be made available. With that, you'd never need anything else. It really sounds good through my chipamps and I suspect a clean amp is where this will shine brightest. I always have trouble with super high gain circuits through my Marshall. The timbre of the distortion reminds me of my Fab-Metal but with less fizz and more meat!
A heartfelt DIY thanks to Electrotabs!
RDV
JimRayden
Better than BSIAB or just "different"? :icon_smile:
Jimbo
RDV
Quote from: JimRayden on May 12, 2006, 12:59:08 AM
Different. They're not even similar IMO. I can(and have) used the BSIAB2 with my live rig because I can turn down the heat and the tone is still there.
I'm not critisizing the DB at all, it's just like a preamp to me more than a pedal. I think you could plug this thing straight into a mixer and out-POD a POD.
RDV
MartyMart
Nice Ricky, it is a very,very good sounding circuit :D
I just built Nelson's "Citrus Graphic MKII" ( Orange amp ) and I'm blown away in
a very similar way, tons of sounds/tones from that one .... and only 4 knobs !!
MM
Bucksears
The Dr. Boogey is nice. I need to check the wiring on mine as I've lost a bit of midrange control; it turns up the treble at the same time, so there's something up in there.
Yes, it's a hot little box. I need to check the bias on my amp because I'm not getting the bass that I used to out of the DB. I've often thought of building a single-rack unit the Dr. Boogey (ala the rackmount 'Tube Driver') or maybe a double-rack and have the JCM800 in the same box. The Dr. Boogey has a warmth (even though it is super-high-gain) that the Metal Zone doesn't.
(on a side note, I started working on the Citrus PCB and have it about 1/3 of the way done.)
- Buck
MartyMart
Quote from: Bucksears on May 12, 2006, 08:54:10 AM
- Buck
You're going to like that .... A LOT !
MM.
RaceDriver205
Quoteis the best sounding high-gain DIY distortion yet.
Gee, thats what I keep telling people! Then they go off and make a blackfire or procorat or something else inferior.   ???
QuoteBSIAB2 with my live rig because I can turn down the heat and the tone is still there.
Thats exactly what I though. Ive never though of the BII as a high-gain, Ive only noticed its 'different' and very nice sound.
RDV
The DB would make an excellent high-gain channel for a DIY SS amp. You'd have a lot of knobs between the 2 channels(My clean preamp I built has 5 knobs and a switch) so it'd be an 11 knob job + a switch. I'd need a huge chassis. I'm wondering(out loud) if a higher voltage would give a bigger output? I suppose it would have to. I run my Thomas/Vox pre at about 15v.
RDV
RDV
I forgot to say I used MPF102 fets in mine to hopefully bypass some of the problems that others have had with noise and oscillation. I think it worked great! I really couldn't use any more gain than this thing's already got happening!
RDV
mydementia
Welcome to the Dr. Boogey fold Ricky! :)
I use the DB so much that I'm getting rid of almost all my other distortion stompboxes (except my Rat and BMP - love those!).
Recommendation:
I just put a Tonemender (http://www.runoffgroove.com/tonemender.html) after my DB set around the 'Marshall' settings - talk about crisping up the tone.  This is the closest I've been able to get to a Mesa Dual Rec out of my Peavey XXX!  Give the tonemender a try - you won't regret it!
Yes, I'm addicted to JFET emu's too...the Orange thing is next on my list...
On the BSIABII - I still don't like mine...built it twice and it still doesn't produce useable tones in my opinion.  So - no comparison to the DB, really!
My JCM800 is quite shrill compared to the rest of my builds...but it sits well with the rest of the band (kick in a little boost (tonemender set around the 'Vox' settings) and I cut right through).
Thanks again to everyone involved in these JFET emus - way too much fun!
Mike
Paul Marossy
Quote from: RaceDriver205 on May 12, 2006, 09:37:21 AM
"thats what I keep telling people! Then they go off and make a blackfire or procorat or something else inferior."
I wouldn't say inferior, just different. People like to jump on wagons when they come by, it's that human nature thing, ya know.
Grocha
theman
Quote from: MartyMart on May 12, 2006, 04:18:01 AM
MM
Can you post a link on where to get the schematic for the "Citrus Graphic Mk II" ?
Thanks.
GreenEye
#13
thanks for the report!  I'd love a sound clip too, but I've heard some already that sound pretty killer.
I might actually try to do a mini-rack version or something.  I really have trouble with small spaces, and wiring.  I think with so many knobs I would go crazy in a stompbox.  I could put the knobs side by side and have a cool half rack thing going on.  I guess I could wire up an external foot switch on a cord, that'd be kinda cool.
RDV
It's been a while since I did any samples but I'll probably do some for this one.
I'm testing it right now through my computer system plugging it into my Mackie mixer along with the PT-80 and it sounds like an amp, no kidding, recording with this thing would be a breeze.
RDV
Marcos - Munky
I can't talk about the Rat, but everything Joe Davisson made/make is incredible. I would never say something he made is inferior.
I saw great build reports for the Dr. Boogey. I will start to build one too :P. Hope it have a lot of mid scoop  :icon_evil: :icon_evil: :icon_evil:.
powerplayj
Quote from: mydementia on May 12, 2006, 10:06:58 AM
Have you tried the Thunderchief yet?  Something tells me that one would sit perfectly in the middle of those two above.  It's slowly becoming my pedal of choice for all-around distortion.
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
RDV
Quote from: Marcos - Munky on May 12, 2006, 12:27:43 PM
It does. I like the mid control a lot, you can either scoop it or boost.
RDV
mydementia
Yep, the Thunderchief is what I use for my Blues/SRVesque stuff - nice OD - very mellow.  Like it better than my TS808 clone.  The TC will also stay on my pedalboard!
Mike
mydementia
Second attempt at a soundclip...just banging around on the guitar but I wanted to share the impact of the Tonemender on the Dr. Boogey.  For S&G I also played with the SSS on and off.  Check out the Dr. Boogey page - I describe the setup and what you're hearing for each segment.
http://www.freewebs.com/mydementia/
