Author Topic: where to buy the supplies?  (Read 9125 times)
KORGULL
Re: where to buy the supplies?
« Reply #20 on: June 10, 2006, 04:44:52 PM »
for the capacitors, does it matter how many volts they are? the ones im looking at are 16v... is that what i want?
16V is perfect for use in building circuits that are powered by a 9V supply.
You just want to consider the maximum voltage that will be running through the circuit and pick components that are rated to withstand a little (or a lot) above that voltage.
