Author Topic: TZF Electric Mistress (sample and layout)  (Read 51037 times)
markusw
Re: TZF Electric Mistress (sample and layout)
« Reply #40 on: September 07, 2006, 07:50:07 AM »
For those willing to invest a second SAD here's the updated link
http://www.aronnelson.com/DIYFiles/up/TZF_Mistress_v11_project_file.pdf
Markus
Dave_B
« Reply #41 on: September 26, 2006, 10:15:00 PM »
Thanks, Markus.  Do you still have the mp3's?
Help build our Wiki!
markusw
« Reply #42 on: September 27, 2006, 03:51:59 AM »
Yup, they are here
http://www.aronnelson.com/DIYFiles/up/wind_me_up.mp3
http://www.aronnelson.com/DIYFiles/up/noise.mp3
BTW, forget about the noise. Since I put it in a box it's absolutely quiet.
Markus
Pierre
« Reply #43 on: August 29, 2007, 02:33:47 PM »
hi !!!
I'm re floating this tread with a couple of questions...
I'm planing to build the TZF board (i allready made 2 pcb's for this project) and i have a little concern about IC 45580...it seems that i can't find this particular chip anywhere...can i replace it with another chip..? I tried to get the datasheet without success so i really don't know nothing about this IC...
Another question is: is it possible to use this TZF board in my A/DA flanger clone...?
Thank you !!!
Pierre
markusw
« Reply #44 on: August 29, 2007, 03:30:31 PM »
hi !!!
Thank you !!!
Pierre
4558O is just a 4558. The O is from the package name in Eagle. Sorry  ;)
Finally,  I went with a NE5532. It doesn't make a real difference though, I just somehow like 5532's...
Markus
« Last Edit: August 29, 2007, 03:32:20 PM by markusw »
QSQCaito
  • Total likes: 2
  • Diego Andrés. Buenos Aires, Argentina.
« Reply #45 on: August 29, 2007, 04:40:05 PM »
Is good you reborn this ;). I have a doubt, you still have your normal flange if you want? Is it worth doing it. And last, can it be done with the deluxe version?
Thanks a lot
bye bye
DAC
D.A.C
Pierre
« Reply #46 on: August 29, 2007, 05:03:05 PM »
thank you Markus...
I can't wait to put both projects together, i pretty much have all components for your 9V Electric Mistress and the TZF board...and definitively I'll give it a try in my A/DA...
Dagreb
« Reply #47 on: August 29, 2007, 10:50:37 PM »
Mark Hammer said:
The Line 6 Liqui-Flange does very nice stereo TZF, and having the TZF move around across two amps is little short of mesmerizing.  Stick a decent fuzz ahead of the flanger so you get lots of harmonic content to comb filter and its damn near paralyzing
Dagreb says:Good to know. The TZF project is beyond me, so....y'know
« Last Edit: August 29, 2007, 10:58:27 PM by Dagreb »
Dagreb
« Reply #48 on: August 29, 2007, 10:53:16 PM »
i'm a doofus. had to edit my post......
markusw
« Reply #49 on: August 30, 2007, 05:48:13 AM »
thank you Markus...
After heaving read puretube's "guidelines" on  having two separate delay lines in http://www.diystompboxes.com/smfforum/index.php?topic=25380.msg166584#msg166584 I now would design the TZF add-on board differently.
Although I didn't notice in the first tests there is a bit of clock noise when the TZF board is switched in.
So it might be a good idea to at least filter the signal going into the second SAD1024. One could e.g. simply duplicate the output filter stage of the TZF add-on board and put it in front of the SAD's input.
Re ADA: I really like the ADA as it is because it's damn close to TZF, especially if you run the clock a bit higher. Also I would be afraid to introduce some clock noise into a really quiet circuit. So in case of the ADA I would go for an external fixed delay.
BTW, recently we compared an original deluxe Mistress with my DIY 9V Mistress. While the sound of those two units is a matter of taste we got serious clock noise when we put the Deluxe in front of the 9V Mistress even when the deluxe was in bypass. So obviously there is some clock noise emitted from the deluxe Mistress that casues heterodyning in combination with my 9V Mistress (this was independent of TZF).
Regards,
Markus
Ry
  • Total likes: 22
  • Made from 100% post-consumer recycled materials
« Reply #50 on: September 01, 2007, 11:25:21 AM »
What did you do to run the clock higher on the ADA, change the cap values?  I can dig through the ADA flanger thread if you documented it there, but I was hoping you would remember quickly.
I'm still not entirely happy with the clock on mine.
Ry
Pierre
« Reply #51 on: September 01, 2007, 01:56:57 PM »
...having the TZF PCB allready done (and a couple of spare SAD1024's) do you think is still worth to give it try..?
One more question :
where should i connect the "bypass" pad in your Mistress project...? (this is maybe a dumb question... :icon_redface:)...
Thank you !!!
StephenGiles
« Reply #52 on: September 01, 2007, 02:03:20 PM »
Look at the circuit and see how the clock is bufferred - that is the trick.
Ry
Ry
  • Total likes: 22
« Reply #53 on: September 01, 2007, 05:54:57 PM »
Ah, so I assume that you mean change the values of the resistors on either side of T4, the 'Max Clock' trimmer to allow more voltage into the op amp buffer before the 4007?  Or is it something downstream of this?
I should just dig through the huge ADA flanger thread and make a useable FAQ out of it, I suppose.
Thanks,
Ry
Branimir
« Reply #54 on: September 01, 2007, 06:40:52 PM »
Sorry for the off topic, I've tried searching the forums for the answer, but what does TZF means?
Umor
Built: Fuzz Face, Small Stone, Trem Lune, Fet Muff, Big Muff (green), Fuxx Face, Son of Screamer, Rat, Rebote 2.5, Opamp Big Muff, EA Tremolo, Easyvibe, Axis Face Si
QSQCaito
  • Total likes: 2
« Reply #55 on: September 01, 2007, 09:47:57 PM »
Through Zero Flanging. I think.
D.A.C
markusw
« Reply #56 on: September 02, 2007, 04:02:43 AM »
Ry
In my build I used for  C29 47p plus 1M for R69. This might allow for higher clock frequencies. However, I believe it should be also possible with the 39p/2M2 combination.
Basically, you should be able to acchieve higher clock frequencies by tweaking T4 (max %^&* trim) and T5 (clock range).
First I checked the available frequency range with a frequency counter. Max clock frequency IIRC was around 4 MHz (measured at the SAD). Then adjusted it by ear and found that I liked it best if the clock went up to about 2,5 MHz.
Hope this helps.
Markus
markusw
« Reply #57 on: September 02, 2007, 04:11:53 AM »
One more question :
Thank you !!!
If you already have the PCB I think it's defintely worth a try. With the switch you can always switch to non-TZF for comparison.
If clock noise is too much you can still remove the TZF PCB or add a filter to it's input to see if this improves the situation.
Maybe first check it out without the TZF board and once you know how it sounds mod it for TZF. This way you know about noise levels without modification.
The bypass pad is for non-true bypass.
Regards,
Markus
Pierre
« Reply #58 on: September 02, 2007, 04:52:31 AM »
I was thinking...what if I put the TZF board in a separate enclosure, will this attenuate some of the noise..? :icon_rolleyes:
markusw
« Reply #59 on: September 02, 2007, 05:01:12 AM »
This is probably a good idea! You could replace the Clock trim pot with a panel mount pot.
Also there will be more space for modding the TZF board  ;)
