Atari Punk Console
Started by z1, June 23, 2006, 10:32:30 AM
Psych0F0x
this might be a really stupid question , but where do I connect negative?
tcobretti
Ground is the bottom left pin on the chip.
Psych0F0x
Quote from: tcobretti on September 05, 2006, 01:18:43 AM
thanks!
It's working but it doesn't really sound like I expected it to. it just makes one constant tone, and you can change the pitch, am I correct? or did I make a mistake somewhere? I doesn't sound very much like that sound clip from the kaustic machines site. I was expecting random stuff
Brett Sinclair
Quote from: Psych0F0x on September 05, 2006, 04:09:22 AMI doesn't sound very much like that sound clip from the kaustic machines site. I was expecting random stuff
On the clip on the machines website i'm weaving my hand above the ldr like a lunatic...  :icon_mrgreen:
You can do fun stuff with this thing... add an ldr in series or parallel to one or both of the pots, make them switchable, have an ldr controlled by a lfo (tremulus lune?)... etc...
suicidalmoose
does anybody want to attempt to make this project a guitar effects pedal, kinda like how an envelope filter controlls a wah, you could convert the signal from the guitar to similar toned atari beeps? I think it'd be kinda cool to experiment with playing some atari game theme songs using a pedal like that and i reckon it'd be a popular novelty pedal, i mean it's a pedal you woudln't be able to buy so surely many would build it.
Psych0F0x
Quote from: Brett Sinclair on September 05, 2006, 04:39:22 AM
I still think I did something wrong, I can't get double tones like you have in your clip,  at 26 secs you get a low tone and a tone an octave higher, with tremelo(ofcourse that could be done with a tremelo pedal). I just get a very tiny variety of 1 straight tone. More like a normal tone than an atari tone. Also one of the other pots only does veery slight pitch shifting or none at all, unless I turn it completely full then it goes up a tone in pitch.
Brett Sinclair
There could indeed be something wrong with your circuit... it should be able to give you a range of "shifting" sounds and both pots should be quite interactive.
$uperpuma
I built one today from Choklitlove's Layout, it is now Verified. Uses a 556. and other than the pot values, it is right on the Mims Schematic.
http://geocities.com/worthekik/atari.html
b2thea
can someone make a layout for the version with 2 555's?
MikeH
Has anyone messed around with the idea of putting this in a box with another effect and using some sort of "blend" control to mix it with a fuzzed out guitar signal or something to the effect?
$uperpuma
you could probably mutate the single oscillator in the Uglyface to a dual oscillator. IT would be a little tougher to manipulate playing guitar and turning two knobs would be hard... even a little more ridiculous, you could use an expression pedal for each osc. controller... ORRRRR you could use an LDR for one and an expression pedal for another.... :) too many possibilities...
Bernardduur
I used two LDR's and it works great!
Am learning something new every day here
SquareLight | MySpace account
choklitlove
Quote from: b2thea on October 09, 2006, 12:09:06 PM
this was posted earlier in the thread:
Quote from: Seljer on July 11, 2006, 09:50:55 AM
Heres a layout for the thing using two 555s based off the schematic on the previous page
my band.                    my DIY page.                    my solo music.
Psych0F0x
I still can't get mine to work right. Looking at the 2x555 layout: Pot B doesn't do much, the other pot changes pitch. Level acts a bit weird. Help??
Gila_Crisis
i built one (with the LM556) and tried now. it work! pretty cool noise maker  :icon_mrgreen:
i like it, now i must only find a little box to put it in a solder the last few things.
Meanderthal
 Just built the dual 555 version... Lotsa fun! One thing to mention though, on the layout posted by seljier pin 8 of Ic2 should go to +9v! Check against the schematic, you'll see what I mean.
Snuffy
I've built two and they both sound pretty good execpt for the second pot on the 556 layout does most of its stuff in the first 1/4 of the rotation, the rest of the way it just farts out.
I'm going to experiment with different pot values to get a better range
Meanderthal
 I used 1m for those. They do stuff over most of their range.
Gila_Crisis
this is the one a build!!!!
today i runed it thru my pedalboard, and messed a bit with all the effects (delay, lfanger phaser, ring mod and wah) preatty sick noise maker :icon_mrgreen:
$uperpuma
i built the etched apc and etched uglyface for a circuit bending buddy of mine and he says hes gotten somegreat tones using the two together into a delay
