Author Topic: Discrete op amp articles?  (Read 11665 times)
Chill
« on: July 10, 2006, 11:49:16 AM »
Do you have links for articles about discrete op amps and how they work?
billings
Re: Discrete op amp articles?
« Reply #1 on: July 10, 2006, 10:00:14 PM »
A "discrete" op amp is simply an op amp built out of individual transistors, caps, resistors, etc, as opposed to op amps contained in an integrated circuit on a chip, such as the 741, TL071, etc.  Both accomplish the exact same thing in a circuit;  the only reason to use the discrete design rather than a ready-made IC is for an application like the one described in this forum, where the op amp is modified to behave differently from available op amps on the market.
This article covers possibly too much information about op amps;  check out the comparator circuit for a pretty clearcut example of the behavior of op amp inputs and outputs:
http://www.uoguelph.ca/~antoon/gadgets/741/741.html
This one covers feedback and high level concepts a bit better:
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/opampcon.html
Also see the schematic for the Distortion+/DOD-250 over at generalguitargadgets for an example of using an op amp as an amplifier in a simple distortion circuit.
Chill
« Reply #2 on: July 12, 2006, 02:25:28 AM »
Thanks for the articles, definitely some good stuff there.
If I were trying to design or modify a discrete opamp like the one described in this project, where would I look to learn about that?
