Here is my first project all in color
Started by Gilles C, July 29, 2006, 09:05:59 AM
Gilles C
Ok, it's not a layout for a new circuit. It's a layout I did for the Tube Reamer 2 for my own use, and I do not pretend it is better than the other layout(s) that already exist for it. It just appends that it's the first one I completed with my new style of project files.
The overall look should stay quite the same, unless I decide to change something like using the bottom view of the pots instead of the top view, etc... But the look of the stripboard layout itself will change though with the new releases of the program I use to do my stripboard layouts.
Any comments are welcome.
So here it is:
http://www.gtechblues.com/My_Layouts/Tube_Reamer2.pdf
Btw, here is the wire (gauge 22, stranded) I bought for the wiring:
http://www.nteinc.com/wire/300.html#22gauge
My color code:
Pair colorSignal
Black & Red(-/+) 9V
Black & WhiteInput
Black & GreenOut to Volume pot
Black & BlueOutput
(If controlled by a positive voltage)
Purple & RedLED effect ON
Purple & GreenLED effect OFF
(If controlled by a Ground)
Gray & RedLED effect ON
Gray & GreenLED effect OFF
Single wireSignal
OrangeDrive pot
Thanks,
Gilles
burnt fingers
Nice work.  I gotta try me a vero project soon.  there are just too many good layouts like this one to ignore the vero anymore.
Scott
Rock and Roll does not take a vacation!!
www.rockguitarlife.com
My Music
Gilles C
The good side of stripboards is that you can do them everywhere, even in your car.
The downside is when you need many of them. That's where an etched pcb is better.
Even then, once you have a layout, it's very easy to make more than one.
I designed and etched many pcbs before, but I came back to stripboards when I couldn't etch my pcbs at work anymore. I then felt in love with them again...
If you try some, have fun.
Gilles
