Author Topic: Potentiometers  (Read 12171 times)
jmac72187
Potentiometers
« on: July 30, 2006, 09:32:02 AM »
I am building the NPN boost with my dad as my first pedal project. I have all the parts for the project except for the potentiometer. The guy at Radioshack didn't grab it when he went through my list. So I have 2 500k pots sitting around. The project calls for 5k pots.
What would happen if I used a 500k pot in its place?
I can get the 5k pot but not right now.
Gus
Re: Potentiometers
« Reply #1 on: July 30, 2006, 12:19:29 PM »
It will not work
The 5k is a part of the design.  It works with the other resistors to set the operating point of the transistor.
sam-sg
Re: Potentiometers
« Reply #2 on: August 09, 2006, 08:13:48 PM »
is the 5K pot the only one that will work because i cant seem to find 1 anywhere  :icon_cry:
ildar
  • Guest
Re: Potentiometers
« Reply #3 on: August 12, 2006, 09:53:43 PM »
Many of the members here order from smallbearelec.com
Steve Daniels, the owner, is a great guy and stocks most of the parts you could ever need for stomps. Check out his site for 5k pots, pretty sure he's got them.
Mihkel
Re: Potentiometers
« Reply #4 on: September 26, 2006, 03:03:52 PM »
A 4.7K might be easier to find.
lovric
Re: Potentiometers
« Reply #5 on: September 28, 2006, 10:43:45 AM »
connect 6k8 resistor in parallel with 500k pot as a first aid measure.
Izzy
Re: Potentiometers
« Reply #6 on: October 08, 2006, 09:10:57 AM »
What is the difference between 16mm pot and 24mm pot?
RLBJR65
Re: Potentiometers
« Reply #7 on: October 08, 2006, 09:30:32 AM »
Those are the width of the pots.
Richard Boop
Izzy
Re: Potentiometers
« Reply #8 on: October 08, 2006, 07:02:31 PM »
So that means it doesnot matter which ever I get?
RLBJR65
Re: Potentiometers
« Reply #9 on: October 09, 2006, 07:03:57 AM »
No it does not matter.
The smaller ones can be easier to mount if you have a small enclosure or you have lots of them in the same box.
Richard Boop
lovric
Re: Potentiometers
« Reply #10 on: October 14, 2006, 08:37:55 PM »
xcuse me for splitting this one hair:
16mm & 24mm are the radii of the knobs. actual pot casing dimensions matter inside the box.
i'm sure you understood each other, but, just in case.  ::) to myself.
jcwillow777
Re: Potentiometers
« Reply #11 on: March 08, 2007, 07:12:32 PM »
I prefer 16mm because they are smaller and take up less room inside the enclosure, especially if you are using several pots.
I used 10K pot is my NPN Boost cause I didn't have 5K and they worked.
