Author Topic: dumb trimpot question  (Read 3624 times)
flavourful
« on: August 19, 2006, 07:41:05 PM »
trimpots have three legs, resistors have two... how does one install them??
AzzR
  • Great Contributor!
  • Total likes: 0
  • Azza - To Much Is Usually Excessive
Re: dumb trimpot question
« Reply #1 on: August 20, 2006, 09:07:36 AM »
You install a trimpot the same way as a normal pot.
A Broken Clock Is Right Twice A Day
aron
« Reply #2 on: August 20, 2006, 03:34:35 PM »
use one outer lug and the middle one to replace a single resistor.
coxter
« Reply #3 on: August 26, 2006, 02:21:21 AM »
So what does the last one do?
AzzR
  • Total likes: 0
« Reply #4 on: August 26, 2006, 07:59:33 AM »
If you are hooking up the pot to function as a resistor the last lug does nothing. You choose which outer lug you wish to use depeding on the orientation of the pot. If you use one lug the resistance will increase when turned clockwise, If you use the other the resistance will decrease when turned clockwise.
-Dream
rosssurf
« Reply #5 on: August 26, 2006, 08:16:50 PM »
So!.. Can one simply remove the third leg from a trim pot if you are using it as a resistor?
AzzR
  • Total likes: 0
« Reply #6 on: August 26, 2006, 11:06:27 PM »
I suppose but I dont see why you would want to, It wont take up any less space and if you decide to reuse it later.....
-Dream
