Author Topic: Bypass works, effect doesnt?  (Read 3754 times)
cat
« on: August 30, 2006, 11:11:50 PM »
Hi all,
I have a problem. Ive populated the circuit board and hooked it up to a DPDT like this:
When I plug the pedal in, and the effect is off its fine.
When I switch the pedal on, it cuts off the sound and the volume pot does nothing.
I figure this means that my jacks are hooked up correctly. Is it a problem with my circuit then?
Any ideas?
Cat
cat
Re: Bypass works, effect doesnt?
« Reply #1 on: August 31, 2006, 01:12:56 AM »
OK I forgot to put the tranny in  ::)
Im still having issues though. With the tranny in, it only gives me short, very loud, very distored, bursts of sound.
Any ideas?
Cat
jonathan perez
« Reply #2 on: August 31, 2006, 01:22:44 AM »
make sure you have it in the right way.
cat
« Reply #3 on: August 31, 2006, 01:43:02 AM »
Cool, Ive got the Tranny the right way.
Still got problems:
When I turn the pedal on, i can faintly hear my guitar if i strumm lightly, if it bash the strings however the pedal seems to kick in and it gives me this intermittant, extremely distorted, bass farting out type sound.
Cat
aron
« Reply #4 on: August 31, 2006, 02:42:24 AM »
You have the classic misbiased transistor.
Here you go:
http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
cat
« Reply #5 on: August 31, 2006, 03:02:37 AM »
I am missing something here.
Going through the test list.
There is no "circuit board end of the black battery lead". Also what is C1, C2 etc?
Cat
« Last Edit: August 31, 2006, 03:17:35 AM by cat »
cat
« Reply #6 on: August 31, 2006, 03:43:41 AM »
Multi set on 20 DCV. Battery plugged in. Lead plugged in. These are the readings I got.
Cat
