Author Topic: A/DA Flanger does TZF?  (Read 325261 times)
BMF Effects
Re: A/DA Flanger does TZF?
« Reply #420 on: January 08, 2007, 11:15:07 PM »
POSSIBLE STUPID QUESTION WARNING!
The population of the PCB is going well. I have a question though. C11, C12, C21 and C32 are listed as (and I'm assuming) 1uF caps. 1uF caps are rather large and I noticed that C11 and C12 have "+" markings on one side. Are C11/12 1uF tantalums? What about C21/32? It just seems that normal 1uF poly caps are too big for the board. Thanks for the help.
stobiepole
« Reply #421 on: January 09, 2007, 12:14:42 AM »
Well, I went for tants for C11/C12 and metal film boxes for C21/C32. The boxes were a little big but no real problem. Hope that helps.
Chris
RedHouse
« Reply #422 on: January 09, 2007, 09:11:11 AM »
Is there going to be a 2nd round of PCB's made anytime?
(I wasn't able to get in on the initial offering)
moosapotamus
« Reply #423 on: January 09, 2007, 09:31:18 AM »
 8) 8) 8) I wish I had time to get started on mine!
BMF - Yeah, I was planning to use tantalums for those.
Red - The first run was 20 PCB's. I'll do a second run if the quantity hits at least the same number.
~ Charlie
moosapotamus.net
BMF Effects
« Reply #424 on: January 09, 2007, 11:20:14 AM »
Charlie - 1uF tants for C11/12/21/32 or just C11/12?
With 20 boards out there I'm surprised there aren't more build reports.  ???
KB
« Reply #425 on: January 09, 2007, 12:46:00 PM »
I'm still collecting parts for mine...... also only have four months left to finish my doctoral dissertation not much spare time at the moment.  I got the board so I could treat myself when purgatory is over.....
Anybody have a source for the MC3403, (other than Mouser), or can I just sub any other quad opamp?
Kevin.
BMF Effects
« Reply #426 on: January 09, 2007, 01:17:18 PM »
Kevin.
The TLE2804 was listed a few pages back as being a good low-noise substitute for the 3403 and there are free samples available from Texas Instruments. I thought I ordered three but they only shipped one. I re-ordered two more last night but haven't received the confirmation email yet so I'm not sure I'll be able to all three. I suspect if TI is suddenly hit with requests for TLE2084 samples they might do away with the free part.
A.S.P.
« Reply #427 on: January 09, 2007, 01:24:49 PM »
SCHEMOS FOR NUTTIN` & CHIPS FOR FREE
Analogue Signal Processing
BMF Effects
« Reply #428 on: January 09, 2007, 01:31:42 PM »
Schemos for free?! Where?!  :icon_mrgreen:
A.S.P.
« Reply #429 on: January 09, 2007, 01:42:38 PM »
StephenGiles
« Reply #430 on: January 09, 2007, 02:04:34 PM »
There is nothing particularly mind blowing there, although I saw one of my old ETI Tech Tips which should be ignored at all costs!
http://www.epanorama.net/schematicsforfree/pdf_redirect.php?url=http://www.epanorama.rackhost.net/schematicsforfree/Audio/Musical/Circuits/Sustainer%20for%20Electric%20Guitar.pdf
oldschoolanalog
« Reply #431 on: January 09, 2007, 02:45:40 PM »
!!!!!!!STOP ABUSING THE FREE SAMPLES PROCESS!!!!!!!
Try a TL074 first. My A/DA reissue uses all TL07XX op amps (and 1 LM324). It sounds *just fine*.
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
A.S.P.
« Reply #432 on: January 09, 2007, 02:54:25 PM »
Horace
« Reply #433 on: January 09, 2007, 02:59:12 PM »
Finally finished mine 2 days ago. This is an awesome flanger !
I just used 1uF 50V polarised electrolytics for C11, C12 and MKT poly caps for C21, C32 (the MKT's aren't an exact fit, but go in easily if the leads are bent to offset the cap body a little). It worked first go but had a squeal when "Enhance" was wound up. I took it into work yesterday and calibrated it as per the calibration guide, it got rid of the squeal and solved a few other very minor things.
For the op amps, I just used all LM324's and a TL072, I don't think it is too critical what op amps you use so long as common sense is used (eg. pin compatibility etc).
It is very easy to lose hours playing around with the settings and finding all the great sounds from this effect.
Steben
« Reply #434 on: January 09, 2007, 03:04:15 PM »
For some chips there is no harm in some samples. Once you start with a small business I agree, but for own experimenting use it's a bless.
BMF Effects
« Reply #435 on: January 09, 2007, 03:26:31 PM »
Since I did not have any substitutes lying around and they only sent me one, I hardly think I qualify for the "Free Sample Abuse 12 Step Program".
 :icon_rolleyes:
oldschoolanalog
« Reply #436 on: January 09, 2007, 03:29:07 PM »
UTSF; free samples. Read the first post. This is the last I will comment on this topic. "This dead horse been beaten enough times." :-X
BMF Effects
« Reply #437 on: January 09, 2007, 03:40:51 PM »
H.U.A.
I'll send it back. However, the free cheese samples they gave out at the supermarket last night are staying in my belly!
« Last Edit: January 09, 2007, 03:47:38 PM by BMF Effects »
A.S.P.
« Reply #438 on: January 09, 2007, 03:41:55 PM »
aarrgh - you caught me there, OSA: I had to for : "UTSF"
bluesdevil
« Reply #439 on: January 09, 2007, 05:29:07 PM »
Good to know folks had their's fire up without debugging!!!  I've been busy finishing other builds, but I think I'm ready to get down to it now. I've got the the TL074's but I'm lacking the 1uf tants, 4007, 15v regulator, 18volt wallwart and a LM324.... guess I still need to make an order with Mouser.
     I'll report back with my results... I may need help with tuning the trimmers. By the way, which trimmers would be useful as panel mounted?
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
