A/DA Flanger does TZF?
Started by Dave_B, September 29, 2006, 05:34:12 PM
powerplayj
anyone going to build the BYOC flanger coming out this Fall?
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
StephenGiles
No, but welcome back this thread.
Giglawyer
ANybody post any soundclips of this yet?
Check out my builds - http://www.giglawyer.com
StephenGiles
#683
oldschoolanalog
Anybody do any mods other than a vibrato switch?
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
markusw
oldschoolanalog
Thanks Markus! I forgot that was  there. :icon_redface:
Nice little layout!
Any tales of TZF w/fixed or swept delay?
markusw
QuoteAny tales of TZF w/fixed or swept delay?
Not really. I think it's already very close to TZF (I run the clock up to about 2,5MHz). So I'm pretty happy with it as it is.
Also,  I'm distracted by other projects  ;)
Juergen Haible's Tau Pipe PCB is waiting for getting populated. Also I'm still planning a Bissell-Follower/Moog LP combination.
Anyway, I think I will porbably add a jack to the ADA for insertion of an external second delay.  I'm a bit scared of messing up the thing with heterodyning issues. It's so estoninglishly quiet. On the other hand I'd love to hear a TZF ADA  :)
BTW, has anyone tried to feed an envelope follower into the ADA's CV input?
You see..I'm easily distracted  :icon_lol:
oldschoolanalog
2.5 MHz?  :icon_eek:
+1 on the jacks for an external feed. That's been on the to-do list for a while. Added flexability. That way it doesn't have to be a delay...
No rules; just fun!
osa
markusw
Quote from: oldschoolanalog on July 29, 2007, 07:35:47 PM
2.5 MHz?  :icon_eek:
No rules; just fun!
osa
Definitely, just fun!  :)
I tried to run the clock even higher (IIRC up to 4-5 MHz).  :icon_evil:  ;)
Problem was, it stayed too long at the high point of the sweep....
Dave_B
Quote from: markusw on July 29, 2007, 04:39:29 PMJuergen Haible's Tau Pipe PCB is waiting for getting populated.
It appears quite a few of us got in on that one.   ;D
Help build our Wiki!
Pierre
hi !!!
i just finished this project. I made the PCB my self for rev. 02 ...it was not very easy, i had to do some Photoshop to make it right and after 3 attempts i made it !
I don't have an oscilloscope and i don't even know how to use one  :icon_redface:, so i had to tune the trims by ear. To my surprise, it works and actually it sounds very close to the sound samples i heard...(I'm proud of me  :icon_mrgreen:). I just noticed one thing that's bothering me : as i did not know the correct orientation of cap 6 (2.2µF) i socket it and i realized that it sound exactly the same in both senses, even more, sound doesn't change at all without this cap...is it me..? did i do something wrong (as usual..? or this cap is not that important...?
Anyway, I'm glad it works, jet flanging and everything !!!
I want to thank all of you for this tread, i learned a lot from it !!!
Pierre
moosapotamus
Congrats, Pierre!
If I recall some of the previous discussions in this thread, that diode bridge that C6 pulls down to ground acts as a limiter that tames high regeneration settings. (Someone please correct me if I'm mistaken.) I would also guess that if you remove C6, you would eliminate any limiting effect. So, maybe try to see if you hear any difference with/without C6 when you have the regen set very high. I think I would definately only try it with the negative leg of C6 going to ground, but you never know... I'd be curious to know what you find.
~ Charlie
moosapotamus.net
Pierre
well, i spend some time adjusting the trim pots, not easy by ear  :icon_confused:...I think now I'm getting the better from this flanger...Anyway  trim pot 6 (null trim) doesn't seem to do anything...
I change cap 6 for a N.P. 2.2µF...but still don't ear any difference, with or without this cap...or maybe my ears are burned !
Thankx again ! :icon_wink:
oldschoolanalog
Your ears are not burned. The limiter won't come into play until the signal coming off the input op amp exceeds ~2.8 V peak to peak. That's the threshold where the diode array conducts. I pre set TP6 dead center, and it worked great from the start. Haven't touched it since. If you checked the output of TP6 on a scope, I would guess you would see a difference. But if it sounds OK, don't sweat it.
Happy adjusting/tuning!
osa
CraigR
Kind of off topic from the original thread, but I am looking at the Moosapotamus's BOM for the ADA Flanger, trying to figure out what I have in stock vs what I have to order from SBE.
Any known problems with subbing;
- a TLO72, 4558 or 4559 for the LM1458 (IC4)?
- a TLO74 for the LM324's (IC's 1,2, & 3)?
- any N-Channel Jfet with the same pinout for Q1 (currently a 2N4393)?
All these seem to make sense. Any known problems based on your experience?
Thanks in advance for your feedback.
Craig
Pedals built to date - BSIABII (x2), AMZ MosFet Booster, AMZ MiniBooster, Rangemaster PNP (negative ground), BMP, Ross Compressor, Liquid Drive (Dist+ variant)
Pierre
...I'm putting together a second A/DA clone...the first sounds so good that I'm afraid to do any mod...
Now i would like to have a control pedal...does anybody knows how to do one...?
QuoteKind of off topic from the original thread, but I am looking at the Moosapotamus's BOM for the ADA Flanger, trying to figure out what I have in stock vs what I have to order from SBE.
Craig
I used TL074 for IC's 1-2-3 and a J201 for Q1, i think it has the same pinout...
I'm not sure for IC 4, i used a MC1458...
markusw
There is a jack for adding an expression pedal (JK3 in Charlie's schem). You don't need to mod the circuit.  :)
Pierre
actually what I meant was that I wanted to build the expression pedal, but I dint know to do it...
Thank you  ;)
markusw
Quote from: Pierre on September 02, 2007, 04:58:27 AM
Thank you  ;)
I think it's cheaper to buy an expression pedal (e.g. a Bespeco).
