A/DA Flanger does TZF?
Started by Dave_B, September 29, 2006, 05:34:12 PM
moosapotamus
Thanks, Stephen!
Quote from: oldschoolanalog on November 01, 2006, 02:13:34 PM
In a VERY oversimplified way of explaining; doubling the value of the cap in the integrator section of the LFO will halve the speed.
So, in Stephen's scheme, that would be the 33uF in the IC4b feedback, yes? I can just add pads to put another cap in parallel with it. Folks can install sockets and try different values to see (hear) what they like best.
~ Charlie
moosapotamus.net
woolley
Nice circuit work. You might need to make the pads a little fatter though, otherwise drill bits might eat them up.
$0.02
puretube
oldschoolanalog
Yes. 2 pads seems like the way to go. After "auditioning" cap values, wiring up a switch would be EZ as can be.
All the Best!
StephenGiles
puretube
ooops, I thought it were a different circuit - hadn`t compared them...
(didn`t know it was yours, even)
:icon_redface:
moosapotamus
Quote from: woolley on November 02, 2006, 06:03:33 AM
I'm planning to have these fabbed... no drilling.
Quote from: StephenGiles on November 02, 2006, 08:25:20 AM
Quote from: puretube on November 02, 2006, 06:52:33 AM
more bounce to the ounce...
It was a few years ago that I drew that Ton!!
Thanks for digging that up, Ton. Nice drawing too, Stephen. At least a SAD1024 is easier to find than a SSM2040 (and more affordable, too!).
Does anyone know where you can hear a good example of what 'bounce' sounds like? The descriptions sound interesting, but I'm not sure I've ever heard what it actually sounds like.
~ Charlie
moosapotamus.net
markusw
Hey Charlie,
I will do some Spice simulations on the various LFO versions this evening. Should give us a clue of the frequency ranges they cover.
Again, thanks for all your work!!
Markus
markusw
I did the LTSpice simulations of the rev3, rev4 and Stephen's MI LFO.
Here are the three schems in comparison:
The calculated frequency ranges of the three LFOs are pretty similar.
Rev3: 40 mHz to 18 Hz
Rev4: 35 mHz to 13.7 Hz
Stephen: 45 mHz to 9.5 Hz
Specs of the original: 30 mHz to 10 Hz
(V(rev32) is for rev3 with double integrating capacity)
As predicted by oldschoolanalog doubling the integrating cap halves the speed (just checked for ver 3: 20 mHz). Thanks for the formula btw! :)
Interestingly, the slow sweep frequencies are all exactly at multiples of 5 mHz. I suppose this somehow correlates with the 200s ( Took ages neverthless ;) ) I used for simulation time and the method of calculating the FFT. Maybe someone can shed some light on it ? :)
Markus
StephenGiles
puretube
goodness: what did you feed in there?  :icon_smile:
markusw
markusw
Quote from: StephenGiles on November 02, 2006, 04:43:34 PM
These are samples from my TDA1022 Standard Electric Mistress  with bounce, which give an idea of what it can sound like.
Fortunately, the ADA Flanger has CV in :)
moosapotamus
Wow! CoOoOol sounds, Stephen! Thanks for posting those clips. I think I'll be after that one. 8)
~ Charlie
moosapotamus.net
StephenGiles
I'm not sure that the placing of the bounce control is understood. I'll post a drawing I did speculating what an ADA circuit with bounce might look like.
StephenGiles
markusw
RedHouse
Not to be a buzz-kill, but the bounce thing (while interesting) doesn't sound like something very useful (musical) to me.  :icon_neutral:
StephenGiles
Quote from: markusw on November 04, 2006, 08:06:20 AM
Quote from: StephenGiles on November 03, 2006, 05:04:20 PM
http://www.aronnelson.com/DIYFiles/up/ADAflanger_bounce.zip
Thanks a lot Stephen! Now it's clear :)
One Q: did you ever try envelope + bounce on Flangers??
Markus
No!
Quote from: RedHouse on November 04, 2006, 09:05:01 AM
Well, it's useful to my ears in just one setting where the sweep goes up to the top, starts to go down and then sweeps up and down again. The sounds on the samples are extreme I would agree and useless in a band situation, but aren't 90% of effects???
puretube
... aren`t bands useless when playing with effects?   :icon_razz:
