Author Topic: done almost  (Read 3629 times)
jtzim07
done almost
« on: October 05, 2006, 11:09:38 AM »
ive got everything soldered together, by that i mean all the leads are connected. where do i put the batter wires? what parts to i connect them to? if i dont want to use a switch, then where does everythign conncet? also, if i cant find that switch, are there substuite switches that can be used, such as a spst switch? would i be able to use one of those? if i didnt want to use a switch, how do i connect the pot, battery, and input and output jacks? is there anything that shouldnt be soldered together? thanks!!!
borman09
Re: done almost
« Reply #1 on: May 02, 2011, 01:37:45 PM »
Most probably you can connected the wire according to the diagram.Thanks
