Author Topic: Need help building Ibanez Tube screamer.  (Read 27422 times)
Re: Need help building Ibanez Tube screamer.
« Reply #40 on: October 12, 2006, 02:07:56 AM »
I have heard people say - you should always solder resistor and other element closer to the board so that they dont act like antenna. Now  I wanted to know if exposing leads of resistor wide acts as anteena or not? Like the one I have made in strip board below? Or is it only the height matter?
  Technically 'they say' quotes are true, having long leads open, even inside the shielded boxes can lead to noise issues. Everybody runs the signal path and other through wires to pots, sometimes longer wires, and any lengths of conductive surface carrying current can add to noise.
  I can't begin to calculate the lead length necessary to do what I suggested ratio to noise increase, but guess it to be undetectable in a TS [it's not super high gain], compared to the <1/4'' added 'antenna' on some resistor leads.
  But it is another variable, once soldered in, it's hard to change.
  It's good to consider how close you want those R's soldered to the board before doing so.
Izzy
« Reply #41 on: October 12, 2006, 02:34:28 AM »
hmmm Thanks once again.
Looks like I will have to re arrange this whole thing  :'(
http://img150.imageshack.us/img150/7219/tubescreamernb6.jpg
Izzy
« Reply #42 on: October 12, 2006, 12:30:27 PM »
So do you think I will have to reararnge the whole thing so that the leads get less exposed to air, which will help to reduce noise? Or is this good enough?
MikeH
« Reply #43 on: October 12, 2006, 01:47:26 PM »
Your layout does have a lot of exposed leads, which could make it prone to excess noise, but I'd be more worried about the size of your layout.  As it is, I don't think it will fit even in a BB enclosure.  At least not comfortably.  If you're doing it on strip board anyway, I'd look for a layout in here:  http://www.guitartone.net/vero.htm
I believe there's one in the Torchy album for the tubescreamer.
Otherwise you're going to have to rearrange your layout to make it more compact.
« Last Edit: October 12, 2006, 01:49:29 PM by MikeH »
Izzy
« Reply #44 on: October 12, 2006, 01:54:10 PM »
Thanks for replying sir.
The stripboard might look kinda big but I guess its 2 x 3" board which I will try to fit in a box.
Yes sir,  I knew the Torhy's layout was available. But I didnt want to copy. As my sole purpose of building pedal was to learn.
I guess I will have to rearrange everything.
1>>>
Can anybody tell me how many lines do I have to leave inbetween for resistor to make perfect horizontal fit in a stripboard?
Is it 2? or 4?
2>>>
Does anybody knows what software did Torchy use for those stripboard layout?
MikeH
« Reply #45 on: October 12, 2006, 02:05:32 PM »
I believe it's 2 holes in between leads to make a resistor lay flat.  But it depends on the size of the resistor.  I'd say 2 holes for a 1/4 watt resistor.  As for the layout; he probably just drew his layout himself using a plain old drawing program.  There are templates in some of those albums.
2x3 might seem like it will fit ok, but space just seems to magically disappear when you start putting wires and switches and jacks and LEDs and DC jacks and batteries... you get where I'm going with this.  Smallest possible is usually the best way to go.
zpyder
  • Great Contributor!
  • Total likes: 1
  • Rc=1/(2pi*f*C) | f = 1/(1.39*R*C) | V=I*R | I=V/R
    • Ultraterrestrial Music
« Reply #46 on: October 12, 2006, 02:19:25 PM »
I'll confirm that "2-holes in between" works well for most 1/4 watt resistors.  I generally think of it as "4 holes across" but who really cares what I think.  There are definately some larger resistors that require 3-in-between/5-across.
chao
zpyder
www.mattrabe.com/ultraterrestrial Ultraterrestrial - Just doing our little part to make new rock go where it should have gone in the late-90's, instead of the bullshit you hear on the radio today.
Izzy
« Reply #47 on: October 12, 2006, 02:21:37 PM »
Thanks a lot. Now I guess I can rebuild the layout again safely .  ;D
« Reply #48 on: October 12, 2006, 03:02:11 PM »
   I never paid a whole lot of attention to having resistors flat on the board [nearest possible to ground plane], and my pedals are all comparitively 'very quiet'.
  Layouts vary from as miniscule as possible to sort of spread out, certainly adding more lead length [antenna] cumulatively than raising resistor leads here and there ... whether this matters for noise much/at all, I'll let others sort out. But add the reason I typed it in the first place is because it's your choice, and I think the noise difference in either case would be indistinguishable to non-existant...compared to other noise sources, and simply because it is not recommended, I mentioned it. Sure makes trying this and that value out alot easier. Another way is to just use sockets, these also raise the component a little bit, I could be wrong, but I don't think it matters....has the chance of mattering some to more with super high gain circuits.
Torchy
« Reply #49 on: October 12, 2006, 06:24:10 PM »
You'll more likely get oscillation than noise with that layout. Problem with med - high gain vero builds is whats being carried by the tracks underneath resistors and caps (and links) as well as lead length. The first couple TS layouts I did had noise and osc problems. That layout is probably generation 5 or 6.
I used MS Paint btw.
Izzy
« Reply #50 on: October 12, 2006, 07:09:52 PM »
You mean Micro soft Paint brush ?? ?? ?? ?? ??
 :o :o :o :o :o :o :o :o :o :o :o :o :o
You must be kidding! ;D
Izzy
« Reply #51 on: October 13, 2006, 09:00:33 AM »
I just wanted to make sure about this gain thing. I wanted to add more gain/distortion to Tube screamer.
so, In this tube screamer if I want to increase the gain it can done by changing 4.7 k resistor to half. right?
And to compensate for the tone I guess I can double the cap value to get the tone I was getting when the resistor was 4.7k, Right?
So If I put 2.2k resistor in place of 4.7 k thenat full gain
Gain = 1+(500+50)/2.2  = 260 ,right?
high pass filter frequency with 4.7 k resistor:
f= 1/(2*pi*4700ohm*.000000047f) =  720 Hz
If I put 2.2 k resistor in place of 4.7 k
So now to find out capacitance value with 2.2k resister :
f= 1/(2*pi*2200ohm*Cap)
720 = 1/(2*pi*2200ohm*Cap)
Cap = 1/(2*pi*2200ohm*720)
Cap = 0.00000001 f = 0.01 uf
So that means I should replace cap with .01 uf if I change resistor to 2.2 for compensation for tone? Is that right?
ubersam
« Reply #52 on: October 13, 2006, 02:53:56 PM »
...so, In this tube screamer if I want to increase the gain it can done by changing 4.7 k resistor to half. right?
Yes. In my last TS build, I went down to 1.5k, replaced the 51k with a 10k so that I will have less drive in the lower settings.
...And to compensate for the tone I guess I can double the cap value to get the tone I was getting when the resistor was 4.7k, Right?
Yes.
Something went wrong with your calculation, you should have come up with 0.1 uf. A 0.01uf cap with a 2.2k resistor would set your corner freq. to 7.23KHz. Alternatively, a 0.1 uf cap and a 2.2k resistor will give you 723Hz.
[/quote]
Izzy
« Reply #53 on: October 13, 2006, 10:50:04 PM »
Oh sorry My bad , that was 0.1 uf. haha
thanks for making it clear.
Is there anyway I could add midboost to the pedal with knob?
Izzy
« Reply #54 on: October 14, 2006, 10:03:54 AM »
any body?
Eric H
« Reply #55 on: October 14, 2006, 10:22:57 AM »
-Izzy, how do you know you want a mid-boost, when you have already modded this circuit and haven't built it yet? My recommendation is to get it built and listen to it through your rig first.
-Eric
" I've had it with cheap cables..."
--DougH
Izzy
« Reply #56 on: October 14, 2006, 10:27:33 AM »
I know this pedal has enough mid boost.
But I just wanted to know how to add Midboost. With low pass filter and high pass filter we can control bass and treble but i wanted to know how do we control MId?  ;D
Izzy
« Reply #57 on: October 14, 2006, 05:59:40 PM »
anyone? :-\
Izzy
« Reply #58 on: October 14, 2006, 10:20:44 PM »
Let me repeat the question   :-X
Izzy
« Reply #59 on: October 15, 2006, 07:08:34 PM »
wow No one?
