Making LDRs "behave" better by tweaking LFO wavefo
Started by Mark Hammer, September 14, 2003, 11:07:58 AM
There has been some discussion as of late on the topic of modulation waveforms.  In particular, the idea of a hypertriangular LFO with one peak being normal linear triangle and the other peak being sinusoidal so as to audibly "decellerate" when a filtering effect of some type starts sweeping towards the low frequency range of its filtering effect, thereby accentuating the effect in that frequency range we are most likely to notice the effect.
At the same time, there has been some discussion of the properties of LDRs and LED/LDR optoisolators.  In particular. some discussion has mentioned in passing the fact that LDRs have a fast turn-on and slow turn-off time.  That is, the drop in LDR resistance when lit is much faster than the increase in resistance after the light source goes off.  This is a real boon in any sort of sidechain-driven device, like a noise gate, or limiter, compressor, envelope-controlled filter, etc., since it has the effect of being responsive to note onset but reducing the envelope ripple that is a naturally occurring part of the minimalist envelope followers that tend to be part of stompboxes, and the problematic signal sources that drive them and have to be detected, and the note decay qualities that create the problems in the first place.
Though LDRs are often far preferable as control elements for both their noise characteristics (low), flexibility of placement (they can go anywhere a resistor can), distortion characteristics (ultra-low), and design simplicity (just work out the relevant R*C formula and there you go), this non-linear aspect of how an LDR cycles through its resistance range can be problematic with respect to LFO-driven effects.  I say "can" be rather than "is" because the problem only arises when one wishes to attain modulation speeds that are faster than the LDR decay-time will accommodate.  In other words, if your sweep cycle is 0.5hz (one full sweep cycle every 2 seconds), then the response time of the LDR is fast enough so that LDR resistance linearly corresponds to where the LFO wave-form is currently at.  Crank up the speed to 3hz or more, and most LDRs tend to choke as the decay-time lags behind - i.e., the LFO has started to climb again before the LDR has reached its maximum resistance.
Okay, here is the central part of this posting.  I've seen schematics for a number of pretty standard 2 op-amp LFOs that have an extra feature of being able to adjust either time balance (i.e., rise time slower/faster/identical to fall time) or else individually adjust the rise and fall times of the LFO waveform to produce waves that are not quite triangular, in addition to the usual sweep width and frequency.  I'm wondering if:
a) these added features would be helpful in producing more linear LDR sweeps when working with faster LFO rates
b) whether anyone has tried it and what it might sound like
I know, for instance that one of the things about, say, the Uni-Vibe that has been discussed is the way the rise-time of the Uni-Vibe's incandescent bulb provides a good match to the LDRs it uses for a more desirable sweep "feel".  I'm wondering if an extra control for skewing the LFO waveform that drives the LEDs illuminating LDRs, whether in self-contained optoisolators or in homebrew LED/LDR combos might help in achieving a more desirable modulation feel.  It certainly isn't that hard to add onto the standard 2 op-amp LFO.  I certainly wouldn't want to make it a fixed setting since, as noted, the interaction between LDR characteristics and LFO speed makes it suitably compensatory at some speeds but not others.
Opinions?
rx5
great Mark.... at last , someone hears my LFO problems.... :o  :lol:
pls post your e-add here.... dunno your e-add.... I want to send my modified LFO diagram ...maybe you could optimize it farther.... :lol:
thanks.... :wink:
BE d Bezt, Urz D Rezt... RoCk ON!!!
The Tone God
Good post Mark. MANY years ago I was playing with circuitry for interfacing an LFO to LEDs or any other device. One of the things the circuitry did was made the central voltage point for the sweep adjustable so instead of the sweep occuring around say 4.5v you could move it to 3v, 7v, or whatever. You can take advantage of the voltage response of the device you are driving thus simulating some of the behavour you mention.
Along with that was a control to adjust the response time of the interface circuitry to the LFO output. There was some LFO waveform "smoothing" circuitry as well to cut down the agressive  peeks at the end of the sweep. I could even amplify the waveform if needed.
None of this circuitry played with the actual sweep of the LFO so you couldn't change the waveform's behavour itself. Just how it drove the device.
Andrew
I guess I should emphasize that what I'm thinking of is primarily restricted to slowing down the rise time of the LFO so that it outputs a slightly ascending rampish wave-form.  The slower rise time would compensate for differential on/off time in the LDR by forcing the LDR to decrease resistance every bit as slowly as it increases resistance: catch-up, if you will.
Bear in mind that since you can't make an LDR go faster than it is able, there are some serious constraints on the extent to which we can even up that resistance change.  Those of you with LDR-based tremolos will note that once you start to crank up the speed, at a certain point you lose sweep depth VERY quickly.  Between that range where the LDR becomes unable to track the LFO, and that range where it is more than able to, however, there must be a sub-range where a little bit of skewing would make it behave better.  Since the skew is relegated to just the rising part of the LFO triangle (or square), all we're really talking about here is maybe adding a circuit fragment and SPST toggle to nudge the skew a bit in a defeatable manner.
Since tremoloes came up, do tube-based tremoloes in amps: a) have a pure triangle LFO, and/or b) track the LFO in a linear manner?  I ask because anyone who has used a tube amp with tremolo will immediately note the very different feel, in comparison to solid-state tremolo, and I'm not sure whether the difference lies entirely in where the amplitude modulation is being applied or the way that modulation is occurring (i.e., rise/fall time, waveform, etc.).
The Tone God
Hmm...I suppose you could make something to compensate for the respose time of the LDR but as you said the limitation at some point will be the LDR itself no matter how much compensation you use. Take in to account that not all LDRs behave the same so you would have to put in a number adjustments to compensate not only the for LDR itself but all the different types of LDRs as well.
If the goal is even response and you don't want the "charm" of the LDR's response time then it might be easier to go to something else like say FETs.
With that said I belive it would be possible but I haven't played with something like that. Just interface circuitry.
Andrew
Peter Snowberg
QuoteIf the goal is even response and you don't want the "charm" of the LDR's response time then it might be easier to go to something else like say FETs.
I think that's probably the avenue with the most opportunity. PhotoFETs are some pretty cool switches.
If you can control the transfer function, you can create the "perfect" LDR; at least in theory.  :wink:
I've wondered how vital the response of an incandescent lamp is in creating the perfect EO response. It's got to have a big outcome as it would add its slowness to the resistive memory of the CdS LDR.
Has anybody played with using LEDs to emulate the response of an incandescent lamp?
It seems like the 3Hz/LDR barrier could be broken with a H11F1, a couple opamps, and a few descete parts. Hmmmm... maybe I'll file that next to "tube emulators".  :lol:  LOL!
-Peter
Eschew paradigm obfuscation
Nasse
In G Andertons famous book "Electronic Projects for Musicians" was that project "Super Tone Control" which is state variable filter or thereabouts. It was told that by puttin in more large caps you could use that to process analog synth control voltages, and that includes LFO s and envelopes I quess.
drew
You know, I was just thinking about this the other day, since I have been obsessed with making a better tremolo for a long time now... and I think I may have the core for an idea.
A vactrol turns on fast, but turns off slow.
My idea: Use TWO vactrols.... in a simple inverting op-amp configuration (mind you there would have to be some trimmers, support parts, etc.) link the LED ends of the two vactrols to an LFO... but have one get an inverted signal from the LFO. Put one of the LDR's in between the signal and the inverting input of the opamp, and put the other one in the feedback loop.
When the LFO is high, the feedback LDR will be low (low gain) and the input LDR will be high (low gain.) When the LFO is low, the feedback LDR will be high (high gain) and the input LDR will be low (high gain.) As one's decaying slowly, the other will turn on immediately to compensate. If fed a square wave, it would look like a low-pass-filtered square wave, but the depth should not be reduced horribly as in most vactrol-based tremolos because at any point, one of the LEDs is going to be able to turn on immediately.
Does that make sense? I wil post a schematic of my astable multivibrator/dual vactrol idea if anyone wants.
drew
BTW: An astable multivibrator has 0 inputs and 2 outputs; the 2 outputs are square waves, one 180 degrees out of phase. It is an extremely simple circuit but I don't know if it'll make the audio signal click... guess I'd better try, huh?
Something I always wondered too: In tremolos which have a clicking problem, why not just use two 9v batteries? Unconnected? Just an idea... when I get some 3pdt switches in maybe I'll try it. (non-true-bypass, but still...)
(Hey, wait, maybe that's where the 4pdt comes in!)
drew
toothpastefordinner.com
Frankgb
Mark,
Some time ago I made the LED driver from the Roger MAyer Voodoo Vibe to drive the LDR'd in an Easyvibe.
It worked fine and had heaps of controls including "symmetry" which does what I think you're looking for.
I made a PCB design for it if you're interested, it uses an 8038 Function Generator IC.
cheers
Frank
drew
For tremolos that don't "cut" enough (i.e. don't have the depth required to completely cut off the signal)....
Wonder if it would be possible to apply a little bit of the buffered incoming signal to the + input of an opamp with a trimmer (with the "chopped" signal on the - input, and feedback for slightly above unity gain) to use the common-mode characteristics of the opamp to "zero out" the signal at its lowest point in the modulation?
Especially for square-wave modulation....
drew
Jay Doyle
Mark, et al.,
There is an easy way to solve this problem, without changing your circuit, your LFO or even not having to use something other than an LDR.
Just use a different type of LDR.
There are two types of LDRs, those made out of cadmium sulfide (CdS) or those made out of cadmium selenide (CdSe). CdS types, which seem to be all that Small Bear carries at the moment, exhibit the problem that you are worrying about, slow decay time. CdSe types have a turn off time nearly as fast as their turn on time and are perfectly suitable for applications where a CdS types turn off time is too slow, such as phasers and tremolos, among others.
The only real difference is in the wavelength that they respond to with CdS responding to red light (about 500 nm) the best and CdSe  responding to green light (about 600 nm) the best.
The hard part is finding them. I know that Clairex makes them in the same numbered series that Steve at Small Bear sells (Steve's are CdS), I just can't find a place that has them for sale. I thought that Hosfelt had some in the past but I can't find them on their site.
Jay Doyle
rx5
@Jay
hello... since youve mentioned thier differences, then how would you differentiate a CDs from CDSe ?? diff color?? by thier form? size? :?:  :?:
Ed Rembold
Jay,
I recieved an order from Clairex in march, at which time they told me that they were shutting down their opto division. Last orders were accepted in april.
Too bad, they were the best.
Ed R.
Lots of good ideas here.
Jay,
Certainly the category of LDR is worth exploring.  My gut sense tells me that this is a mail-out job since just about everything I've seen locally is CdS.  I think my thinking may have been too limited in past by the looming spectre of CLM6000's.  Obviously there ARE other types of LDRs worth exploring, so thanks for jogging my thinking a bit.
Frank,
The layout would be of interest to me.  I've got an 8038 in my parts bin (purchased for a synth VCO at the dawn of recorded history I think) so this might be very handy.  You can send it to mhammer@ccs.carleton.ca
Drew,
I think I get the gist of what you mean.  Basically, your intent is to use two LDRs in different places that set gain, and use the point on the light/resistance curve of one to offset the point on the light/resistanc curve of the other.  In principle it seems plausible, although obviously there are some details to be worked out. such as how much resistance change can be accomplished in X amount of time.  Seems like there is a lot of tweaking ahead.  Not a reason to NOT do it, just that I don't have hopes for it simply falling into place right away.  There may be some series/parallel resistor tweaking too.  The other thing, of course is that this is limited to gain adjustment and can't be made to work for phasers, or other filter-type devices.   Still, seems worth pursuing.
Andrew,
The noise/distortion/ripple-immunity distinction between FETs and LDRs remains firmly in place.  Even with a decay time chopped in half, the instantaneous response of an FET pales in comparison to an LDR with respect to ripple-immunity.  So while photoFets are sure as heck handy, small, easy to buy, etc., LDRs just make some things easier.  I have somne H11F1's in the bin.  One of these days I'll have to throw two copies of something together with photoFETs and LDRs to demonstrate the difference in ripple and signal handling.  Who knows, I may well be overselling LDRs, when it comes to real-world needs (as opposed to ideal-world specs).
I like this thread.  It's brought out some useful thinking in folks.
Jay Doyle
Ed, well that just shoots that all to hell doesn't it? I know other manufacturers make them I just don't have any links available. That will certainly make things harder.
rx5, sorry, there isn't a way to tell the difference just by looking at them. Chances are though if you see a LDR, it will be CdS. That is all that Mouser carries. I'll look into it some more.
Mark, great thread.
Jay
drew
I am prettying up this circuit to get it ready to draw the schematic... and also trying that "feed in the original signal" idea to get more "chopping" out of it.
Theoretically the dynamic range is about 60dB at 10hz... It is a little mushy, but I am going to try tweaking things a bit to see what I can do about that.
I am also interested in potentially using more than one in series/parallel (LEDs in parallel, resistors in series) to get a wider range out of it... No idea if this would work, though.
drew
rx5
Hi guys,
just wanna clear up things.... :)
what color of LED is best for use on an LDR (cds) ??
in mutron, it was green.. some say RED is or has the best sensitivity...some white....
so what really is the best color of LED to use for CdS ??? to get the best possible usage of it..
thanks...
blackbox
It depends on what kind of LDR you are using.  The color sensitivity range is usually listed in the specs.  CdS are generally more responsive to yellow or green and CdSe to Red.  The spec sheet should give you a peak response in nm that you can then compare to an LEDs Peak Wavelength value (also in nm).  I have some application info, etc. for optos on the blackbox DIY section at http://www.blackboxmusicfx.com/diy.html
One thing that I don't think has been mentioned is plain ole FETs for voltage control.  They are not the greatest for audio, but for controlling other voltages, they are a cheap and good substitute for photo FETs for apps where distortion and feedthrough aren't a problem.
Lorren
Blackbox Music Electronics
Quote from: rx5Hi guys,
thanks...
Peter Snowberg
Has anybody played with units from Silonex?
Most photocells are made of either a Cadmium Sulphide (CdS) or Cadmium Selenide (CdSe) photoconductive material. Either material is suited for specific applications, but only a compound of the 2 material will optimize audio performance and remove significant audio performance issues.
See:
http://www.silonex.com/audiohm/constants.html
They have effects for application circuits too! 8)
http://www.silonex.com/audiohm/compressor.html
-Peter
