Author Topic: Tonepad CE-2 Chorus op amp selection question.  (Read 3974 times)
boogietube
« on: January 02, 2007, 09:27:00 PM »
So I can't find a TL022 op amp for this project, but I have a tube of NE5532'S that I picked up for a song. The data sheets have the same pinout for both op amps. Can I use them? Will they sound worse? Better? The same?
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
jonathan perez
Re: Tonepad CE-2 Chorus op amp selection question.
« Reply #1 on: January 02, 2007, 09:29:33 PM »
i also have a bunch of 5532s...so id like to know an answer to the same question.  ;D
ive got a pair of tl022s, but i want to know too.
in know for sure you can use tl072/82.
Cliff Schecht
« Reply #2 on: January 03, 2007, 02:04:58 AM »
They'll work fine and will have a better signal-to-noise ratio than the TL072 and the 022, plus they have a better slew rate (about 8v/uS vs 13V/uS).
lowstar
« Reply #3 on: January 03, 2007, 02:23:18 AM »
somebody correct me if im wrong (its been some time since i completed my ce-2), but from what i remember, there is no tl022 in the signal path, but only in the lfo section...so the better slew rate and what not should not matter...it is a bit easier on the batteries if i remember correctly...and very expensive nowadays  :icon_mrgreen:
cheers,
lowstar
effects built counter: stopped counting at 100
Cliff Schecht
« Reply #4 on: January 03, 2007, 02:26:10 AM »
Same here, I don't quite recall the schematic, but you may be right here. I think I used a TL022, I had one laying around.
stephanovitch
« Reply #5 on: January 03, 2007, 04:11:59 AM »
If you use battery for your chorurus, the TL062 comsuption is more interessant than NE5532 : 200A for the tl062 and 8mA (minimum) for the NE5532
MartyMart
« Reply #6 on: January 03, 2007, 04:52:42 AM »
I think you're right lowstar , TLO62 best choice ( battery wise) and TLO72 is fine too.
I have a couple of 022's from my GE7, so may try one !
In the GE7 they were in the signal path and a bit noisey
MM
wui223
« Reply #7 on: January 03, 2007, 06:13:37 AM »
Does the op-amp colour the sound? Year ago i built a Small Clone, when tested by a luthier friend, he said it COLOUR the original guitar tone too much. Any remedy?
« Reply #8 on: January 03, 2007, 10:06:25 AM »
Op-amp choice will be different for the LFO and audio paths.  A common low-noise dual op-amp is fine for the audio path.  A TL072 will do nicely and so will an NE5532 (at a cost of a bit more current draw and shorter battery life).
To keep clicking to a minimum, you'll want a lower current dual op-amp for the LFO section.  I suggest an LM358 since we know that a) the Small Clone uses them with success, and b) you can pick them up at Future Electronics in town, whereas TL022 will have to be ordered in.  I think I used an LM358 on my own CE-2/Corrral and it is clean as a whistle.  I think you may have even tried it out at my place, right?
boogietube
« Reply #9 on: January 04, 2007, 05:53:50 PM »
As usual, the definitive answer from Mark Hammer. Thanks, Man.
I actually have some TL072'S . A LM358, mmm . It's the Rat one I believe. Think that I've got one of those too.
Yes,Mark, I auditioned the CE-2 chorus at your place which led to the decision to build it. We compared it and the Small Clone, I believe. The CE-2 won flat out. Much deeper and more lush chorus in my opinion. At least through your vintage Fender amps ! Tone Tone! Have you ever built a commonsound project?
Just wondering if new auditions are in the future!! Any luck on the tube amp studies? I'm thinking of building one.
 Sean
boogietube
« Reply #10 on: January 04, 2007, 06:06:28 PM »
LM308 - rat
LM358-Don't have. :'(
I'll try a TL072 as suggested.
