Author Topic: ce2 chorus not working........dangit.....  (Read 3556 times)
jonathan perez
« on: January 09, 2007, 10:03:09 PM »
ok, where would i find a RD11EB zener diode? because the one i got from mouser MAY be the culprit. its a 5020A.
ill keep measuring around, but everything is looking GOOD...but voltages cuts in half right after the zener diode.
any ideas?
Morocotopo
Re: ce2 chorus not working........dangit.....
« Reply #1 on: January 09, 2007, 10:31:59 PM »
I used:
RD11EB: replaced by a 12V/0,5W zener diode
TL022: replaced by TL062 (could also be TL072)
1N914: replaced by 1N4148
Works fine.
Hope it helps.
Morocotopo
Morocotopo
jonathan perez
« Reply #2 on: January 09, 2007, 10:44:36 PM »
oh...replaced so that it WORKS, or so that it works better?
MartyMart
« Reply #3 on: January 10, 2007, 05:10:58 AM »
As it's just a power supply protection diode, a 1N4001 or even a 1N4148 will do fine, that's
what I used.
TL062/72 - also fine 100% as replacement
1N4148's - direct replacement for '914's
MM
jonathan perez
« Reply #4 on: January 10, 2007, 10:38:35 AM »
the sound right now is...well..nothing! i get no change in sound. and the voltage drops off SOMEWHERE, so ive got to pinpoint it...this sucks... :D
ill swap those ICs and report back..
Morocotopo
« Reply #5 on: January 10, 2007, 12:35:01 PM »
Replaced as in, I never used/tried the original parts. RD11EB: couldnīt get. TL022: extra/super/ extra expensive in my country. 1N914: unavailable in my country.
Are you sure the diode is oriented correctly?
Morocotopo
Morocotopo
« Reply #6 on: January 10, 2007, 02:31:09 PM »
The circuit will work perfectly fine without the diode in question; just don't plug in the wrong adaptor.
I think I'm using an LM358 for the LFO in mine.  Never actually set eyes on a TL022 in my life.
Do you not get anything or is this a case of simply not getting a chorus effect?
Barcode80
« Reply #7 on: January 10, 2007, 02:40:29 PM »
i have 2 TL022's on my bench right now, sitting in my defunct DOD delay :( I think you have an unpowered opamp. check voltages on the IC's.
jonathan perez
« Reply #8 on: January 10, 2007, 02:51:27 PM »
no chorus effect, at all. trimpot does nothing...
i dont have anything besides a tl022, right now...at least i dont think...ill take alook in my parts bin, see what i have.
im going to swap out the 4558 too, to see if maybe i put in a dead one...
jonathan perez
« Reply #9 on: January 10, 2007, 03:09:56 PM »
nope...still not working...ill post voltages and go over with a microscope to see if i did any blotchy solder jobs, tonight.
thanks!
« Reply #10 on: January 10, 2007, 03:29:01 PM »
If you have a meter, check to see what the AC voltage is on the input of the BBD while you strum.
As well, what sorts of sockets are you using, good ones or bargain basement?  I've had a few instances where I couldn't locate any source of nonfunctionality, and when I jiggled the chip in the socket or dabbed some stuff in to improve the contacts, all of a sudden the thing came to life.  I recommend using good quality machined sockets for any of the critical expensive chips in a project.  At least that way yuo can be certain the source is NOT that chip.
jonathan perez
« Reply #11 on: January 18, 2007, 02:40:53 AM »
ill check that right now!!!!!
also, i noticed that on the TP CE2 project page, on the picture of the CE2, the transistors are orientated the opposite direction...may that be my problem?
sockets are fine...hmm....
oh right, VOLTAGE!...
« Last Edit: January 18, 2007, 02:48:59 AM by thebattleofmidway »
MartyMart
« Reply #12 on: January 18, 2007, 05:02:28 AM »
If you used the same trannies, then the pinout and orientation SHOULD match the
layout, if you used others, then you may need to check the pinout and adjust !!
That one will get you EVERY time  :icon_wink:
MM
