Author Topic: RF Switcher  (Read 9044 times)
RaceDriver205
Re: RF Switcher
« Reply #20 on: April 26, 2007, 03:23:03 AM »
This is diffinately not for MIDI. Its only for switching effects on/off remotely from a distance up to 200m.
hgamal
Re: RF Switcher
« Reply #21 on: April 26, 2007, 11:06:20 PM »
....From what I've seen, controller events are typically pretty data intensive.  Is the idea to have all the effects at the soundboard, or are we just talkin?    :icon_smile:
I am just thinking about applications where you switch patches, changes volumes and iterate expression parameters like wah, delays or pitch. I have no figures to present but I think it is possible to have such controls over 2400 bauds. Am I wrong?
Haroldo Gamal
johngreene
Re: RF Switcher
« Reply #22 on: June 14, 2007, 06:37:03 PM »
As long as no one has a garage door opener near by!  :icon_lol:
Seriously, 315 MHz and 433.92 MHz are very, very common remote control frequencies for everything from garage door openers to keyfobs for your car. Without a sophisticated addressing, encoding/decoding, FEC scheme, I wouldn't trust it anywhere I really needed it to work when I wanted it to. And even then, being ASK it is totally sensitive to being jammed and/or desensitized.
I've desinged a lot of these type devices, many for remote control of an iPod. Some of which you can buy at Best Buy!
--john
Seljer
Re: RF Switcher
« Reply #23 on: June 16, 2007, 05:54:29 AM »
not sure about the expression pedal stuff (as that probably would require a bit more bandwidth), but you could just make the pedal board with the footswitches to change the patches and such that'd send only the data about what switch was pressed, and make the receiver do all the work of converting it into MIDI program change messages
RaceDriver205
Re: RF Switcher
« Reply #24 on: June 16, 2007, 09:28:49 AM »
yes, that sounds perfectly feasable.
