Author Topic: Only inexperienced builders check this out :-)  (Read 19960 times)
timrand
me too
« Reply #40 on: September 21, 2003, 10:57:31 PM »
i am in
30 ips
  • Guest
« Reply #41 on: September 22, 2003, 02:28:26 PM »
What do we need?  Where do we get it?  When do we start?
I AM IN!!!!!
Aranha
  • Guest
Re: Only inexperienced builders check this out :-)
« Reply #42 on: September 23, 2003, 10:05:48 AM »
I´m a really newbie, I´ve never done anything... but I really want to start.
1wahfreak
« Reply #43 on: September 23, 2003, 11:04:45 PM »
I'm all for it. Is this something that might happen before Nov. 1st? Otherwise I'll be on a long needed 6 week vacation and would miss it.
Greek Acrobat
« Reply #44 on: September 25, 2003, 02:05:06 PM »
This is great! I've just started with circuit bending - about as simple as it gets. I'm still waiting for a kit I've got on back order from paia.com. Such a good idea.
Count me in.
d a e r h t a y b g n u h
dex kemp
  • Guest
« Reply #45 on: September 26, 2003, 04:39:05 AM »
i wanna learn to!
trex03mt
  • Guest
Beginner Project
« Reply #46 on: September 26, 2003, 11:30:20 PM »
i am a true newb (just found your site a day ago. it looked interesting so i registered right away), but i am anxious to learn if i'm not too late.
aron
« Reply #47 on: September 26, 2003, 11:45:45 PM »
Follow the steps (Sticky threads) in the forum.
I will be adding to it so you can follow along anytime.
We will follow up with real-time chat too.
blabj
a small question...
« Reply #48 on: October 15, 2003, 06:17:12 AM »
is it too late to join? i have already made 2 projects but they both dont work any more, so i would really like to do a project that is (as close to) impossible to fail :D
thanks
blabj
P.S im only 13 so ill probably fail it  :(
blabj
im stupid...
« Reply #49 on: October 15, 2003, 06:40:06 AM »
ok looking through your ther posts i can see that the solder-a-thon has already happened. poo. so i will have to use your page on how to do it. but i have one major problem... i cannot find this transistor anywhere, well not in maplins catalog, sooooo my question is, is there a substitute part for the transistor?
thanks
blabj
aron
« Reply #50 on: October 15, 2003, 03:07:14 PM »
Go to any electronics place and ask for any small signal NPN transistor.
They will work. 2N5088, 2N5089, 2N3904, 2N2222
any transistor on this page that says small signal transistor:
http://us.st.com/stonline/books/toc/ds/194.htm
BTW: it should cost anywhere from about 10 cents to 1 dollar (USD).
GOOD LUCK!
blabj
« Reply #51 on: October 16, 2003, 04:07:18 AM »
ok thanks :). i am a little confused about the hookup wire though... do you use stranded or the solid core type?
thanks
blabj :)
aron
« Reply #52 on: October 16, 2003, 04:11:44 AM »
You can use any type of hookup wire.
Here's the basics:
stranded can handle flexing and will not break as easily.
solid core will bend and stay bent and is good for placement in a box when you want it to stay put. Solid core WILL break and easily if bent enough times.
pre-tinned wire from Small Bear is excellent and exhibits properties from both types of wire. It stays in place and can flex better than solid core.
I use stranded or pre-tinned. That reminds me, I need more pre-tinned from Small Bear.
blabj
« Reply #53 on: October 16, 2003, 04:54:50 AM »
ok thanks but i cant get it from small bear because to ship a metre of wire to england costs £10 (ok slight exageration :) ) but i am definately making it!  :D
hendrixxx259
« Reply #54 on: July 13, 2006, 10:57:18 AM »
It would be great if you could show some of us how to build a simple box. I think the NPN Booster would be great.
"When the power of love overcomes the love of power, the world will see PEACE."
KZiggen
« Reply #55 on: July 15, 2006, 04:35:45 AM »
am i too late? or can i still join? i have never touched the inside of effects and have no knowledge... :(
but i am willing to learn, im still looking for a place where they sell some stuff
im in japan which means no radio shack...
alvintang
« Reply #56 on: July 15, 2006, 02:57:14 PM »
this thread is actually almost 3 years old.
the tutorials for the npn booster is already up on beginner project thread.
they are labelled as 1. tools, 2. schematic and parts list.........
gd luck.
« Last Edit: July 15, 2006, 02:58:48 PM by alvintang »
