Pot's confusion ...
Started by TiMe25, September 15, 2003, 01:08:50 PM
TiMe25
I need some help with pot's. I just wanna know what mean the letter behind the value .... in some cases mean:
A=log.
B=lin
but in other
A=lin.
B=log.
Now i'm confused !!!
TiMe25
aron
Very strange.
I guess you need to ask the dealer.
As for testing them, just use the method in the FAQ
http://www.diystompboxes.com/cnews/FAQ.html
QuoteA=log.
B=lin
This coding is more conventional, I call it the Japanese system.
Some manufacturers (mainly western contries) make up there own codes and often these conflict with other manufacturers - all this does is create problems.  That aside I have seen pots incorrectly marked in the shops as well, usually the ones that have a sicker on them instead of the pressed metal markings.
The best way to be sure is measure it.  Set the pot to half-way (as accurately as possible) then measure the resistance from the wiper to the clockwise lug and again from the wiper to the counter clockwise lug.  For a linear pot the two measurements will be about the same.  For a 10% log the counter clockwise lug measurement will be 9 times the clockwise lug measurent (for a 20% log you will get 4 times).
