Author Topic: led indicator  (Read 3947 times)
Zayden
led indicator
« on: March 30, 2007, 11:14:53 AM »
hi,
i've made a classic muff, it sounds great, but i need a led indicator, how do i do it? i put a led and tried every combination no the switch (6 pin stomp switch), and i tried one end to the battery plus and the other on the switch, that way it works fine, but when i plug the input it only changes the strength of the light, but upside down, when it works it's mid-light, when the pedal is off, the led is in full power.
what can i do?
aron
Re: led indicator
« Reply #1 on: March 30, 2007, 01:09:15 PM »
6 pin stomp switch so DPDT? then the FAQ is your friend:
http://www.diystompboxes.com/wiki/index.php?title=DIY_FAQ
Search for true bypass and switching.
Aron
12milluz
Re: led indicator
« Reply #2 on: July 16, 2007, 11:08:11 PM »
You could also try using the 3PDT switch instead.
Quote from: Processaurus
You need a glade plug-in, in on a footswitch.  Kick on the big muff, then hit the air freshener pedal.
Visit my site: http://www.freewebs.com/12milluzmusic
CGDARK
