Hey, I am a bit confused over the analog and digital ground business. ive done some digital logic stuff and plenty of analog but untill now havent tried to fuse them together. I am also attempting to build an effects switcher and i was drawing up my schematics realizing that i was not personaly confident with the concept of the different analog and digital grounds.
So on the MT8816 you have VSS (digital ground) VEE (negative supply) and VDD (positive supply). and my understanding is that the logic 1's and zero's are between the VSS and VDD. so my confusiion comes with two things. 1: if i am having audio signals connected directly to the chip i am asuming that i would bias them at VSS so that the signal has the most headroom peak-to-peak. is this wrong? and 2: if my mcu is going from ground to 5.5 V how to i connect the two so that the logic will match? sorry if these are obvious questions i searched but all i got was mention of the concept and not an explanation.
thanks as always
Jose
